Question about Vehicle Parts & Accessories
I need to program an autopage xt-33 remote. the remote needs to be programmed im not sure if it has a valet chip or not
  • jesus Nov 16, 2011
    i need help programming a remote for autopage xt-33
  • Anonymous Mar 20, 2014
    How to program the remote key
  • 365 Answers
Autopage is a pretty trouble free system...but if the battery is near-dead or dead they can do evil things...swap out the battery and try again...If you can't...go to your local car stereo installation shop and ask them NICELY to help...lots of times it's free..if it is, buy the dude lunch...what, $10?
Good Luck
Posted on Jun 15, 2009
How do I program the key pat
Posted on May 14, 2012
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Autopage XT-1100
Try to search for Autopage XT-1100 Manual. im sure you will be able to find the functions there
Apr 01, 2014 | C3RS730 LCD (C3RS730LCD) 2way 4Channel...
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jan 14, 2012 | RS855LCD AutoPage MultiChannel 2 Way...
Need to know how or get instruction to program new auto page xt-100 oled remote starter.
REMOTE TRANSMITTER PROGRAMMING Enter: 1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in ON position. Within 15 seconds. 2. Push the Valet switch 2 times and hold in on the 2 nd push, when a long chirp is heard then release the valet switch. You are now in the Transmitter programming mode. Program: 1. Press the Lock button on transmitter 1 until the siren responds on Car with a confirming chirp; the first transmitter is now programmed to Car. Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps will confirm exit. Note: If more than 4 transmitters programmed, the system will only keep the last four. The Valet switch is a little Red Push Button that should be mounted under the lower left side of you dash or in the lower left kick panel near the E-brake pedal.
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING13.pdf
This sis atndard programming for the 900,915,1000,and 100 units.
Feb 12, 2011 | RS1000 OLED 2Way OLED Remote Start w 6...
I am having problems with my alarm/ remote start system. My remote is not comunicating with my truck
I am the senior tech support person for Autopage. You will need to do 2 things. First you need to unplug the antenna and let it sit for a few seconds. Then plug it back in. Attempt to hit unlock on the remote. Next step is to completely reprogram the remotes. This can be done by turn the ignition ON 3 times, and then leaving it in the ON position. (ON/OFF, ON/OFF, ON) then press the RED VALET switch 2 times, and holding on the second push (push valet and release, then push valet and hold). Once the siren lets out a long chirp, then release the valet switch, and program the remote by hitting the LOCK button on the remote itself. Program all your remotes you have, until you have programed 4 remote controls into it. It will cancel any prior remote codes. If you still cannot get this correct, you can call my technical support office at 1-800-945-2527 x600. And i will walk you through it.
Aug 23, 2010 | C3 RS900LCD 900MHz SixChannel Alarm System...
Program remote
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
How to re program my pager? (autopage 1000
Enter:
Program:
Jun 03, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Autopage XT-59 wont chirp and lock/unlock doors. plz hellp batteries are all fine, cant figure out how to reset remote
FIND THE VALET SWITCH AND PROGRAM MANUAL. REPROGRAM YOUR REMOTES. IF THAT DON'T WORK MAKE SURE YOU HAVE 12 VOLTS AND A GOOD GROUND CONNECTION AT THE XT-59.
Sep 27, 2009 | Vehicle Parts & Accessories
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Feb 17, 2009 | Megatronix - TW71 - 5 Button 2 Way LCD...
Vehicle Parts & Accessories Logo
5,472 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
