Question about Ovens
Nutool doncaster spares for lawnmower
Need lawnmower blade
Can you replace the heating element on lamorna 4400 cooker from the front? thanks MS
Hello Malcolm Shaw,
Lamorna 4400 resolves to the other side of the earth on the bottom half... Looking for "PARTS" (usa: here) didn't work
"SPARES" did... (not dawn here yet = SF Bay Area)
I was looking for a nice VENDOR VIDEO...
"you-tube" videos vary from reality... (a wee bit)
or are just plain wrong.
Sorry I could not find you a direct answer.
My best advice is to "CHAT" with a "SPARES"
retailer (example below)
Lamona Spares Spare Parts Appliance Spares Appliance Parts BuySpares
Mar 11, 2017 | Ovens
I am looking for the "INNER" glass from the door of a LEF6EGSS.
Hello Julie;
Contact the following website for your part.
Peter
Glen Burnie, Maryland, USA Appliance Spares Appliance Parts Spare Parts Stokes Appliance Parts
Jun 04, 2015 | Ovens
I have had my nutool cordless drill since 2001. It is one of the best drills I have owned. It is now slipping and I think the metal cogs are worn. I had a quick peek inside and near the back is a square...
If you can repair it below the cost of a replacement , do it , or if not buy a new one . After 5 years it is time for a new one anyway , it is amortised already .
Nov 01, 2013 | Ovens
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
Need selector switch for upper oven
If you are in the u/k, then try these sites
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
If elsewhere, then type in BOSCH SPARES in the your browser bar, and you should be able to find someone who supplies Bosch spares.
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Spare part number?
499003 available on line at neff spares remove back panel 6 screws lift up and out 3 screws holding element
Nov 23, 2009 | Neff U1721 Double circotherm Electric Oven
Why does my Jenn Air convection oven make such a LOUD clattery/ticking noise whenever I use it? I think it must be the fan...can you help?
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Ovens
I need to locate a spare parts list
Hi, this should help you with your parts search. i have located a TC oven spare parts list that should help. click below to be directed.
CLICK HERE
May 20, 2009 | TurboChef C3 Single Oven
New world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Aug 14, 2008 | New World G60m Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
