Question about Sony VAIO VGC-V520G (VGCV520G20TVPC) PC Desktop
The part I am trying to install is a Desktop 10/100 Mbps PCI Network Card That is what I was told I needed
    President:
  • 1,865 Answers
What problem do you have installing the card?
Posted on Jun 15, 2009
What is the PCI speed?
I think the question is which pci slots do you have. You have PCI. You do NOT have PCI Express.. to confirm, see picture here:
Conventional PCI
PCI Express Has MUCH smaller connectors and several speeds
PCI Express is not to be confused with PCI-X
A pix will help:
Various slots on a computer motherboard, from top to bottom:
  • PCI Express ×4
  • PCI Express ×16
  • PCI Express ×1
  • PCI Express ×16
  • Legacy PCI (32-bit, 5 V)
Aug 07, 2015 | HP Pavilion a340n (DQ099AABA) PC Desktop
Download TP-LINK TF-3200 Ethernet 10/100 Mbps PCI Card
http://download.cnet.com/smc-ez-card-10/3000-2112_4-70830.html
http://download.cnet.com/allied-telesyn-at-2700tx/3000-2112_4-64130.html
if these drivers are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: ethernet driver
you might have to try a few times to get it right
hope it helps
Jul 05, 2012 | TP-LINK TF-3200 Ethernet PCI Network...
HOW TO INSTALL DYNEX DESKTOP 10/100 MBPS PCI NETWORK CARD
Remove the case cover from your desktop computer.
Remove a cover strip from a PCI expansion slot.
Insert the Dynex network card into this PCI slot and secure it with a screw.
Replace the cover on the desktop computer.
Boot up the computer and when Windows has booted up then insert the Dynex installation CD into the CD drive then install the LAN driver.
Connect a LAN cable from the Dynex LAN card to your modem or router etc.
Mar 11, 2012 | Computers & Internet
How do you install a 54 mbps wireless pc card (wg511) Netgear to a desktop computer?
You can use a cardbus/pcmcia to pci adapter card just like this one below:
Nov 03, 2010 | NetGear WG511 54 Mbps Wireless PC Card
I need to replace the Ethernet card but I see no card. All the Ethernet/USB ports are linked together in a small box. They look like they go directly into the motherboard. Suggestions???? I checked all the...
Sure you can't see the Ethernet card because that is integrated motherboard so that means all the controller cards(graphic, audio, network) are in same place in chip set.
First try to uninstall network drivers and to install again if that will not work you can install PCI network card (they are very cheap).
Jul 24, 2010 | Dell XPS 410 PC Desktop
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Is ddr upgrade to 1 gig for gateway mdw 500s? Is there a way that I can install a nic/ wireless card to pick up signals?
we need model number of the laptop please mdw 500s i cannot find listed. If its the same as the nx 500s then ddr 333 is required (200 pin sodimm modules)
for wireless they installed
Intel® PRO/Wireless IEEE 802.11b/g network card, Mini-PCI Pentium® M models only)
-OR-
Broadcom IEEE 802.11b/g network card, Mini-PCI (Celeron™ M models only)
  • FN+F2 keyboard combination toggles wireless networking
  • Antenna: Uses factory-installed internal antenna assembly
  • Operating channels: 11 selectable channels
  • Security: 128 and 64 bit WEP encryption
  • Operating Frequency: 2.4 GHz Direct Sequence Spread Spectrum
  • Maximum Data Rate:
    54 Mbps (IEEE802.11g)
    11 Mbps (IEEE802.11b)
I am not sure where you will find a mini PCi card to suit i would just use a slot in pcmcia card or usb adaptor
Jan 10, 2010 | Gateway Computers & Internet
Ethernet card
Hello my friend thats ok.
Is just that the site i gave you, you can easily find what you are looking for from different maker and model of cards from different mnufacturer but if you cant go to this site of Dell ethernet card ok
You can use any ethernet card just depending on the slot it will go into ok
now take this site :
www.accessories.us.dell.com or
www.startech.com/category/parts/networking/network-cards/gigabit-adapters/list.aspx
MSRP st1000bt32.athumb.jpg 10/100/1000 Mbps 32 bit PCI Gigabit Ethernet Card
ID#: ST1000BT32 $29.99
ec1000bt.athumb.jpg Gigabit ExpressCard (10/100/1000 Mbps) Network Card
ID#: EC1000BT $55.99
st1000btpex.athumb.jpg PCI Express 10/100/1000Mbps Gigabit Ethernet Card
ID#: ST1000BTPEX $69.99
cb1000bt.athumb.jpg Gigabit CardBus Network Card (10/100/1000 Mbits/sec.)
ID#: CB1000BT $64.99
RATE THIS SOLUTION
ok
Oct 16, 2008 | Computers & Internet
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
Sony VAIO VGC-V520G (VGCV520G20TVPC) PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
