Question about Tefal ActiFry Deep Fryer
Paddle rotating wrong way - Tefal ActiFry Deep Fryer
Took paddle off to clean but now can't get the paddle to rotate, help?
Add enough near boiling water to cover bottom. Wait 5 minutes. Drain off water. Add oil that you would use to make next loaf of bread. Rotate paddle back and forth to loosen up. I always add oil first to "lube" paddle shaft.
Apr 30, 2014 | Kitchen Appliances - Others
Tefal actifry paddle will not rotate
Replace the paddle motor. Spares are redily available on Amazon
Mar 28, 2012 | Tefal ActiFry Deep Fryer
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Cleaning
You have to hold the button (above the blending jar) down while turning the rotating paddle in the ice hopper. It will eventually catch, then you can unscrew it, take it apart, and clean it. Just be careful not to cut yourself on the shaver blade.
Nov 21, 2007 | Margaritaville Frozen Concoction (DM1000)...
Paddle not rotating
The paddle is supposed to scrape the frozen mix off the inside of the can as it turns. So yes, that sounds right.
Oct 18, 2007 | Rival 8420-TB 4 Quart Ice Cream Maker
Motor runs, but paddle doesn't turn
groove has worn out replace it if you can get parts.good luck.
Sep 28, 2006 | Krups 358-70 La Glaciere 1.5 Quart Ice...
Tefal ActiFry Deep Fryer Logo
49 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
