Question about Filter Queen Vacuums
Filter queen just stopped working
Where is the fuse
While vacuuming filter queen just stopped
What is the model number? If you enter this number on google you will be able to access an owners manual and find out.
May 01, 2014 | Filter Queen Vacuums
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Need Filter Queen Majestic Owners Manual
I downloaded and printed a Filter Queen Owners Manual from the Filter Queen.Com website. It was hard to locate on their website, but I printed it free.
Dec 01, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Repair Service Essex United Kingdom
when you mean overhaul is the motor not working or are you experiencing loss of suction or wha seems to be the problem?
Nov 09, 2008 | Filter Queen Majestic Canister Vacuum
Stopped working
I had a simular probleme with my older model filter queen vac and it turned out to be worn brushes on the motor I simply ordered new ones installed them and then and all it costs was 15.00 usd to canada probably less in U.S. go to this site you'll find all you need there. www.lighthouseenterprises.us
Aug 29, 2008 | Filter Queen Majestic Canister Vacuum
Just stopped working
mine has a reset on the power head. alittle red button the back. if it is that old and worn out i would buy a refurbished one on like think i saw one for around $350. just search filter queen and u will find them
Aug 20, 2008 | Filter Queen Majestic Canister Vacuum
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Vacuum Just Stopped
Could be a bad switch or a bad cord would be the first things to check.
Jan 04, 2008 | Filter Queen Majestic Canister Vacuum
Majestic filter queen not working
could be power switch or power cord, happens alot
Nov 13, 2007 | Filter Queen Majestic Canister Vacuum
Vacuums Logo
12 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
