Question about Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7
I can't connect to my internet. I go to settings and turn on wifi but the wifi turns off by itself and my internet wont pop up when i selected wifi on.
Can't connect to my internet when i turn my wifi on
I have a brand new amazon fire 7 and am trying to set it up. First how can I see how much my tablet is powered up? And how do I connect this device to my internet?
Charge it. Press and hold the power button. If shows a battery by itself it's dead and it's not charging. If it's a battery with a lightning bolt symbol it's dead and it's charging. If it turns on, go to settings, find wifi settings, turn wifi on, find your wifi network, and enter the password for your wifi.
Aug 25, 2017 | Amazon Tablets & eReaders
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
Aug 11, 2017 | Tablets & eReaders
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
How does the iconia one 7 tablet hold the wifi password without you having to type it in every time you turn it on?
When entering the password there is a tick box that allows you to save the settings and connect whenever this wifi available, check the settings from the password page!
Dec 27, 2014 | Acer Iconia One 7 B1-730HD-11S6 7-Inch HD...
How do I access the WiFi Internet Connection With Tablet
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
How do I get internet on my.tablet
Hi Tara, if your tablet is WiFi compatible, it should have an option in the settings to select a WiFi source and connect. Most will require the correct password.
If it is and Android tablet you can swipe down on the screen and press and hold on the WiFi button to turn it on and select which source to connect to.
If it is and iPad, you can go to settings and enable it there, then select the WiFi source and enter the password.
Hope this helps. Don't forget to comment/rate the sollution or ask further questions on this thread.
Jul 15, 2014 | Tablets & eReaders
Have wifi on ipad but it wont connect to internet
Try resetting the network settings.
Here is an Apple Support Article that may help.
http://support.apple.com/kb/TS1398
Apr 03, 2014 | Apple iPad 32 GB 3G Tablet PC
Authentication problem when trying to connect Kindle to internet
go into settings and select wifi a list will pop up select and connect
Mar 01, 2014 | Amazon Kindle Fire HD
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Ipad wont connect to internet
Go to settings and then wifi if it is off switch it on and then select your wifi router and enter your password
Dec 15, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Mach Speed Trio Stealth G2 Tablet - Android 4.0 Ice Cream Sandwich, 7 Logo
Top Mach Speed Trio Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
