Question about Kenmore Washing Machines
My washer won't turn either but you can hear the motor running
Kenmore 4270090
Turns out after looking underneath there is no belt on this model just a direct drive transmission, turns out the coupler broke between the motor and the drive
  • 15,935 Answers
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Locate the water pump. It is a small plastic pump with two hoses connected to it, directly under the front of the wash tub. It is advisable at this point to drain the residual water from the wash tub. This will save you a lot of clean up time later. Here's a helpful HINT: If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall. Connect the shop vac to the end of the drain line and pull a vacuum on it. This will quickly drain the residual water and leave you with little to no mess. If you do not own a shop vac, remove the lower hose from the pump and place a pan or a bunch of old towels under it & allow to drain.
8. Remove the water pump by removing the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and remove both hoses. HINT: This is a good time to inspect the drain lines for any debris that may have gotten lodged in the lines.
9. Install new water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly on the motor shaft. Make sure you re-install the retaining clips correctly. Insert the keyed end first, then turn and snap them in place over the pump.
10. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
11. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
12. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
13. Reinstall console.
NOTE: This water pump IS NOT serviceable. Meaning, it does not come apart. You can, at times, manage to dislodge items that have become stuck in the pump by slowly rotating the shaft backwards (with the pump removed from the washer) while pulling the object free. Sometimes this works, but sometimes the seal becomes damaged. Panty hose, underwear and the under wire from bras are notorious for getting stuck in these pumps. HINT: It is STRONGLY recommended that you use small nylon garment bags while washing some of your smaller items like this.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Need to replace the drive belt (I think!) on a Whirlpool washer model# 110.20912 990. The agitator won't turn but I can hear the motor run. Please tell me how to replace the belt. Thank you!!!
According to the model number you provided, there is not a belt on your machine. Probably what has broken is the coupler between the motor and the transmission. http www searspartsdirect com Kenmore Washer Parts Model 11020912990 0582...
Look at part # 13 the coupler. Hope this helps!
Feb 17, 2015 | Whirlpool Washing Machines
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
I have an elite model 11024942301 and the spin cycle won,t work
check your lid switch. If you hear the motor running, your problems can be a coupler(Whirlpool), belt, clutch, or even a transmission problem.
Nov 10, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore cloths washer, model #110.24642300. The other day it filled up with water and stopped working. If you try to turn it on now, it does not do anything. But you can hear a small hum or...
The belt may be in place but it appears to be loose and slipping. Probably worn out. You hear the hum because the motor is running but the belt will not let it drive. When you have it apart make sure the part the belt is driving turns by hand.
Jun 14, 2017 | Kenmore Washing Machines
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Kenmore Washer hums during spin cycle
Either the bearings are frozen, or motor is weakening and has hard turning belt and tub/agitiator
Sep 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washing machine Model #11082984120 will
it IS driven by belts you need to either replace the belts youself or call in a serviceman.
Aug 01, 2009 | Washing Machines
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
