Question about Eagle Fishelite 502c Igps Fish Finder Combo
Will not switch on even though power is supplied
Connections are live but when the power button is pushed the unit still does not boot up.
My Bosch CSB 650-2RE works fine when drilling horizontally, but as soon as it goes vertical the power goes off, even though switch is still depressed
You probably have a loose wire at one on the connections inside the unit. Open it up and have a look at all the connections, pay special attention to any push in connections as they tend to get loose over time.
Mar 02, 2015 | Bosch Drills
My desktop suddenly suspended, switched it off by pressing the power button. Now it does not boot, the screen stays dark, though power lights on the PC and keyboard are on. What should I do?
You are the owner of a desktop PC that has developed a sudden and catastrophic hardware
fault - probably on the motherboard (since even the ROM BIOS doesn't give evidence of its
existence), but possibly in the power supply.
Desktop PC power supplies are (relatively) easily replaceable, so if you have as many spare
power supplies lying around as I do, try replacing that first - if that doesn't fix the system, then
the problem is on the motherboard.
Since your power supply is alive enough to light the power LEDs on the system unit tower and
also the keyboard, the problem is probably on the motherboard - look at it - there may be an obviously burned visible component - but there usually is no visible sign of the fatal failure.
The reason I do not suspect your HDD (hard disk drive) has crashed is that ROM BIOS
executes at (power start) boot time right out of motherboard-mounted ROM, independent of
whether or not the HDD is functional - and since not even the BIOS message appears on your monitor, I therefore know that the boot sequence has been interrupted long before the computer becomes intelligent enough to find and access a disk drive, and then command it to try to find a
boot sector.
How to fix the computer: isolate the boot problem to the motherboard. Replace motherboard.
Sep 05, 2011 | Epson Computers & Internet
My pc starts up without pressing power button, cant switch it off with power button so iff i switch it off on the power supply and switch it back on it immediatly starts up not showing anything on screen...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
May 25, 2011 | Gigabyte GA-EP43-UD3L Motherboard
I have a Gateway Intel Pentium 4 that won't turn on, the power button light turns on but nothing else. The power supply test switch shows that the power supply is good, and when the switch is pressed all...
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 26, 2011 | Gateway Computers & Internet
Green turn on button will not come on just orange lite. green button don't turn on at all nor will computer boot up. model T2865 bought in 2007
Apr 22, 2011 | E-Machines Emachine T2865 Power Supply...
I push the power button It doesn't boot all the fans come on the light come one and a second later it off, then it tries again, it keep trying to cycle but can get anywhere. I have just assembled this...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 10, 2011 | Computers & Internet
I have a Dell PE2900 which is not starting. The (single) power supply has a solid green light when plugged in. When I press the on/off button, it turns green, but nothing happens; no post, no fans, no spin...
This doesnt' look like the motherboard right away. First I would try the unit with another power supply. Using a power supply tester may let you know that the unit can give power or turn on but does nto mean the PSU is able to work with a load.
Many time dell will still have the lights even though the PSU is bad. On the back of the unit when you hit the power button. There should be status messages etc that can tell you if the unit detects issues.
This manual: http://support.dell.com/support/edocs/systems/pe2900/en/hom/html/about.htm#wp1072621
will help you. Pay attention to the Power Indicator Codes and LCD Status Messages sections.
Mar 08, 2011 | Computers & Internet
My epson stylus CX5500 printer is unable to be switched on even though it is connected to a power supply. Regardless how long I've pressed the button, the printer just refuse to come to life. How can I...
First Check the power source e.g. make sure: the outlet you are using has juice if not change over to a new outlet. Make sure all the connections and plugs are properly inserted. If the Unit still does not power up I would just return it etc.. Also try just pressing the button once quickly and check the manual for quick start up instructions. Hope this helps:)
Jul 24, 2010 | Epson Office Equipment & Supplies
I push the on button and nothing happens. is it
Even though a lot of things might have gone wrong and caused this, especially if where you place the System is not well ventilated, and the CPU becomes very hot, it shuts down automatically...and you will have to wait for a few moments, get a cool environment and power it on. but I will also try and tell you some troubleshooting steps that you can try.
Since you have already checked the power source and all is Ok, then try this out:
Disconnect your PowerPack(Power Supply Unit) from the CPU and try to power your PC with another Power Pack (Power Supply Unit), that you are very sure is working.
If it powers up, then just get a new Power Pack(Power Supply Unit) for system.
If you cant do this yourself, just get a good technician to do it for you.
Try this first and let me know how it goes, so as to know the next step.
Hope this helps.
Nov 21, 2009 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Eagle Fishelite 502c Igps Fish Finder Combo Logo
41 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
