Question about Garden
Moodel s1970 poulan
Fuel lines into carb
    Problem Solver:
  • 17 Answers
Are you looking for a routing diagram?
Posted on Apr 23, 2014
5 Suggested Answers
  • 149 Answers
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Posted on Jan 12, 2009
  • 97 Answers
SOURCE: fuel line routing help.
You should have one line (with filter) going to the carb inlet & one line going to the bulb then back to the tank.
Posted on Mar 17, 2009
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
  • 2239 Answers
SOURCE: diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Posted on Jul 05, 2012
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Replaced gas tank and primer bulb on my Poulan Leafblower FL1500 and it appears I'm not getting gas into the carb. Any ideas as to what my be the cause?
I assume the new tank came with new fuel lines and filter in it.
First be sure you have all the lines hooked up correctly. There should be a main line from the tank ( has the fuel line on the end of it in the tank) to the fuel pump side of the carb. Then there should be a line leaving the metering side of the carb to the primer bulb then from the primer bulb returning to the tank. When you press the primer bulb you should see it **** the fuel into the carb then from the carb into the primer bulb then back into the tank.
If the fuel lines are all hooked up correctly then you should rebuild the carb.
Jan 02, 2010 | Poulan Featherlite Gas Blower, with Low...
Which lines hook to what?
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Aug 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan S25 Chainsaw - fuel line replacement
should only be top cover and access fuel line through filler cap with long nose pliers first remove line from carb
May 13, 2009 | Poulan Garden
Routing of fuel lines from tank to primer bulb to carb
Mar 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line routing help.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
My poulan wont start any suggestions
Plugged fuel line or carb due to sitting with fuel in tank. Drain tank and back flush line, changing filter if there is one. Inject some compressed air into fuel line from carb.jet screw hole, thus blowing out line toward tank. May have to also use some carb.cleaner in same area.
Prevention: Always shut off fuel line and run carb dry before storing unit. If storing a long time, remove all fuel as gasoline will not keep long, esp. in the carb.
Best wishes!
Feb 10, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
