Question about LG LFX25976
Not c ooling
Compressor not running but all fans are.
Cooling fan on my neff oven stays on when I set it in auto is this normal
Are you sure you mean 'C ooling Fan' and not 'Circulating Fan' which should come on if the temperature selection is higher that the current temperature.
Oct 10, 2016 | Neff Ovens
Fan not spinning
If the fan on the backside is not spinning it could be a bad fan-motor. When the fan runs the compressor should run as well. If the compressor is not running the fan should not be running either, so you should unplug it for about an hour, then plug it back in and see if the compressor unit starts up. If it doesn't, it is probably something wrong in the control circuit for the compressor. It could be the thermostat (check that it is set correctly). If the compressor starts up but the fan does not run, it is most likely a bad fan motor or bad wire leading to the fan motor.
Jan 20, 2014 | Cuisinart CWC1600 Wine Cooler
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
We have a Kenmore 596.50399001 side by side refrigerator. The center divider can get very hot, the refrigerator compressor is running but not the fan. If the refrigerator is moved or shook the fan will...
If you are talking about the freezer fan motor, it should be running if the compressor is running.
if the compressor runs without the fan running the compressor will overheat and become damaged.
The mullion heater in the door divider is not affected by the compressor.
Mar 13, 2009 | Kenmore Refrigerators
Fan running but compressor is not
which fan is running? evaporator fan or condenser fan?
if the condenser fan is running and the compressor is not, try to feel the compressor if it is VERY hot,
( use caution please)
if it is very hot, unplug the unit, put some wet rags on top of the compressor and let it cool for a while.
after 4 hours, try it again, plug it back and observe the compressor if it would run,
let me know what happen,
tnx 4 using fixya,
drcool
Sep 26, 2008 | Whirlpool Refrigerators
Compressor fan
This sounds like it is caused by either a high pressure reset. Or the compressor is tripping a high temperature limit internally. One thing you may be able to do is to hose off the coil surface with a garden hose on the outside (condensing unit) this would allow the operating pressure to drop if it is dirty.
Hope this helps Ya
Jul 06, 2008 | Goodman CLJ36AR42 Air Conditioner
Side by side LG GR-L207DXZA
Compressor Fan does not rotate at right speed or at all. So that one have to be changed. Br Ismo
Dec 25, 2007 | Refrigerators
LG LFX25976 Logo
44 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
