Question about Peltor Mt15h67fb Tactical 6-s Slim Line Electronic Headset With Audio
Circuit board electronic ear muffs peltor
K83A ver 06 R2.5
How to water flush a mercury 4hp 2 stroke
You will need the flush-kit adapter also known as ear muffs. You connect your garden hose to the ear muffs, then start the motor. It is a good idea to first prime the motor befor trying to start the motor. Then turn the water on right after the motor starts.
Nov 01, 2016 | Boating
Hi, can I get the replacement ear muffs for this headphone? Wear and tear. Thanks, Jeremy
perhaps from the manufacturer . we however do not know who that was.
Jun 08, 2016 | Audio Players & Recorders
Do I need to protect my ears when the weather is very cold?
Yes, ears are very sensitive parts of the body and can be vulnerable to frost bit in very cold weather. Use ear muffs or a hat to protect them.
Feb 20, 2013 | Health & Beauty
How to put peltor bluetooth into pairing mode
Normally Peltor headsets work as follows:
1.) Turn the device off.
2.) Once off, hold the on/off/mode button for 5 seconds until you hear a voice say "pairing mode"
3.) Make sure bluetooth is active on your device and search for the Peltor headset, once you find it select it.
4.) When prompted for a pairing key use 0000
that is 4 zeros.
5.) Headset should say pairing complete.
As with moth bluetooth devices remember this muse bt done within a normal amount of time so have your device ready to search by time you put headset in pairing mode will help.
Dec 22, 2012 | Peltor MT53H7BWS2 Bluetooth Headset
Nwz x1060 earphone socket faulty
This type of problem is quite common. The fault is usually a dry or weak solder joint on the ear phone socket on the circuit board.
This can be repaired by removing the circuit board from the player to get access to this socket and resoldering the phone socket connections.
I suggest you use a fine tip soldering iron. If you do not think you can DIY then ask a savy friend or take it to an electronic repair shop.
Mar 04, 2012 | Sony Audio Players & Recorders
98 vw bettel alarm car dose not want srart
Alarm module may be faulty. Or your keyfob is out of sync with the Beetle. Disconnect the battery from the beetle, and wear ear muffs when you do or ear plugs as the horn is likely to go off. Remove battery from key fob and let both sit for 20 minurtes. Then put the batteries back in /connected- this should get both back into synchronization. If they do not resynchronize, the alarm module is suspect.
Feb 18, 2012 | 1998 Volkswagen Beetle
15 hp outboard 2 stroke running with water muffs on,there is no water coming out of the **** tube? Check the impeller? where is it? Just bought the the motor.
Impeller is at the bottom in the housing. it may take a few mins for the water to come out of the tell tale hole. Ensure that your muffs are on properly and wait for a bit. Also insure that the hole is not plugged.
Sep 07, 2009 | Boating
Peltor Mt15h67fb Tactical 6-s Slim Line Electronic Headset With Audio Logo
118 people viewed this question
Top Peltor Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Peltor Radio Communication Expert? Answer questions, earn points and help others
