How to preset stations into memory with a **** smith a4785
Can't make preset channels work with memory
SparkGap
  • 363 Answers
SOURCE: radio stations memory preset
Manually tune to the station you want to store.
Press and hold the button you want to store it to for a few seconds.
Posted on Oct 13, 2007
  • 99 Answers
SOURCE: panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Posted on Nov 27, 2007
SOURCE: RX-397 FM Station presets, both in Auto or Manual, DIFFICULT to control.
I took a deep breath and realized that I had to push memory twice. Once to engage and once to set.
Posted on Apr 28, 2008
easyq
  • 144 Answers
SOURCE: JVC RX 809V home reciever
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Posted on Aug 08, 2008
welcomejee
  • 10594 Answers
SOURCE: resseting the preset channels
Please download user manual of Aiwa XR-MN5 from here. This will help you to set new stations presets.
Posted on Oct 11, 2008
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
How do you work the channle preset
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
Oct 20, 2010 | Dewalt DC011 AM/FM Radio
How do I enter stations into memory and then recall them?
First select your station by scanning,than press memory button,while it is flashing select your preset channel thru preset buttons that you desire to have it and push memory button again.(you must act quickly otherwise flashing stops that you need to start from zero) .your channel is now in the memory.To recall ,simply press the relevant preset channel..good luck
Jan 12, 2010 | Audio Players & Recorders
I have an RX-DT680 unit on which i am trying to set the preset FM Stations to and am wondering what I have to do to accomplish this?
1. Select desired channel 2. Press " tuning memory" until "program" flashes 3. Press " preset tuning" up or down to select position 1-10 4. Press " tuning memory" again, flashing " program" disappears 5. Channel is now selected @ position 1-10 6. Find channel @ selected site by pressing "preset tuning" up or down
Oct 02, 2009 | Panasonic Audio Players & Recorders
Pioneer deh4000ub radio wont save
Six stations for each band can be stored. 1 Press LIST.
Preset screen is displayed.
2 Use MULTI-CONTROL to store the selected
frequency in memory. Turn to change the preset number. Press and hold to store. You can also store the frequency in memory
by pushing and holding MULTI-CONTROL right.
3 Use MULTI-CONTROL to select the desired
station. Turn to change the station. Press to select.
You can also change the station by pushing MULTI-CONTROL up or down.
To return to the ordinary display, press BAND/ESC or LIST.
Jul 18, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
I have the manual.
1. Press the FUNCTION button to select FM or AM mode
2. Press SKIP to select station.
3> Press and hold the Memory button to enter channel saving mode.
4. Press the Memory button to select desire preset channel #.
5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
6. Repeat step 2 and 5 to store addtl. stations.
Any idea as to how to set the volume during alarm mode, it's too loud!!
Jun 04, 2009 | Audio Players & Recorders
Other option:
Aug 08, 2008 | Audio Players & Recorders
Setting preset radio stations
Hallo, I had the same problem and found following solution: first search the station you want to preset. Than put the the little round button below on the right side called enter/time and on the same time the button of the number of the memory preset you change.This number will appear in the display an remain the preset. Sorry about my English - I hope you understand however.
Feb 04, 2008 | Sony SRF-M10 FM Radio
Setting presets on KLH R3100
No, not so easy, this isn't like your average car radio, unfortunately. This was driving me nuts, too, but I finally found a manual. Hopefully you have a remote, since that is needed.
Once you are on the station you want to save, press MEMORY on the remote. MEMORY will blink on the receiver's display. While MEMORY is flashing, press the button(s) on the remote for the number you want to save the station under.
Neil
Sep 28, 2007 | KLH R3100 Receiver
27 people viewed this question
 Grubhead
Grubhead
