Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Ice in freezer and warm refrigerator Zisb48dyb
We have had multiple problems with our GE monogram refrigerator model Zisb48dyb with built in ice maker and dispenser. The first inkling of a problem is a warming refrigerator then ice in the freezer on top and right side on common wall with the refrigerator. Then freezer warms up to above freezing. The GE technician said this is a technical flaw with the unit. The drain tube ices up and the solution is to unplug refigerator and let it warm up for 3 days to unfreeze the tube. They said there is no other solution. This is happening every month or so now and seems that this should be repairable for a $9000 refrigerator. Need some help here or to reengineer the drain tube as apparently i t is embedded in the wall of the refrigerator.
  • GE Master
  • 842 Answers
If I remember correctly, GE had a issue with the drain pan as it would clog or restrict and back up in the freezer and in the air return (hence, water under crispers if refer section). GE has a repair kit for this and they have also changed the drain hose to prevent self restricting as it leaves the freezer. This part is an Icing kit part# WR49x10021, this comes with complete instruction as to what your changing and why. This should solve your drain and water problem, if this is what your issue is. I hope this was helpful.
Posted on Mar 31, 2014
  • majorbean Apr 01, 2014
    It may be a temperature sensor (thermistor) problem. Try the following link to a video: http://www.appliancepartspros.com/ge-tem...
    oops. I forgot to say that I followed that video but the thermistor was NOT located where they said it was. Instead, it was under a plastic vent that was on the cmmon wall that separates the freezer from the refrigerator. The vent just pops off and exposes the thermistor. Cost of thermistor: $14 from local vendor and $9 on line. THere is another temperature sensor that sits on the evaporator coils in the freezer compartment. If you have easy access to these coils, then could try replaceing that thermistor as well.
3 Suggested Answers
k_killigrew
  • 11 Answers
SOURCE: My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Posted on Aug 28, 2012
SOURCE: hi. I have a GE Monogram refrigerator/freezer
I have zfsb26dnd and it does not freeze or cool ther refigerator
Posted on Oct 13, 2012
GE Monogram side by side built in model # ZISB48DYB. Freezer side ice cold but the refrigerator side is very warm/ hot no cold at all
Check to see if your fan is running, if its running your more than likely have a damper issue. check the damper on the top of the fridge and see if air is coming through. if not you need to replace or repair the damper.
Aug 05, 2013 | General Refrigerators
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Water leaking from top of freezer into icemaker and right side of freezer. Coils, etc. are clean.
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Jul 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice Maker Quit Working
Replace the whole i/m - it is bad. Takes 5 minutes to do. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | GE Monogram ZISS420DRSS Stainless Steel
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
165 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
