Question about Tablets & eReaders
UPGRADE tm105a TO 4.2.4
How DO UPGRADE AN iNTEL tm105a FROM 4.0.4 TO 4.2 OR ABOVE
How to get on my iPad a 5.0 or a 6.0 ios
First Generation iPads can use iOS 5
- but iOS 6 / 7 / 8 need an iPad 2 or newer and are not compatibel with first gen. iPhone
-updates can be made in iTunes connected to a computer or under settings - general - software update
Upgrade iOS from within iOS device
(valid for iOS 5 and above)
Since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update). To upgrade to iOS 6/7/8, simply navigate to Settings > General > Software Update. The screenshot below demonstrates how to do so on an iPad, but this is also valid for the iPhone and iPod Touch.
in iTunes:
get-ipad-5-0-or-6-0-ios-fsa0em3gpfye3khtm1m3hcbs-2-2.jpg How to update to iOS 7
Jan 03, 2014 | Apple iPad Tablets & eReaders
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
How do you upgrade the Android OS to support the Kindle app?
"http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=11918&ProdId=944&lang=eng"
and thank to o770
Jul 28, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
I'd like to upgrade the hard disk to 64 Gb. With one I need to buy? Thanks Arie
Might just want to buy the NEWER CFU1!! It'll cost you about $960.00 to upgrade yours!!
http://www.provantage.com/panasonic-cf-wsdu1031~4PSO90TV.htm
Apr 08, 2011 | Panasonic Toughbook CFU1 Rugged Ultra...
I'd like to upgrade the memory from 1 GB to 2 GB on my cf-u1.
upi cam u need to buy a ddr2 667 mhz stick (2gb) as i think there is only 1 onboard slot for ram. hope this helps let me know
Mar 17, 2011 | Panasonic Toughbook CFU1 Rugged Ultra...
1.mainly i want the memory capacity of gatawayCX210X tablet pc.... 2.what kind operating system is used in it? 3.how about effient performance? 4.what kind processor is used in it? kindly please do...
1) 4 gigabytes (Comes with 1 GB) 2) Windows Vista Home Premium (32-bit) 3) Inefficient, but this is my opinion. For starters, it is an old processor, with little memory to support it. If you want to upgrade to the 4 GB capacity, you need a new license to Windows Vista Home Premium x64, so that adds cost. If you can't perform the upgrade yourself, that will add more cost. This is not a fast system. 4) Intel Core Duo T2350, though some were produced with a single-core variant, in either setup, this will not be a very fast system. Depending upon your use, you may want to shop for a newer system. This system would be good for note taking, but not graphic arts, and I would not expect a snappy startup time with Windows Vista. Sorry to be the bearer of bad news, but better to find out before spending the money. Always try a system out before buying it, because numbers can be deceiving when you are reading specifications.
Mar 10, 2011 | Gateway (tabletpc)
I need wireless drivers as i am not able to connect to my wreless network. Can you help me to configure to the wireless neetwork Model: Itronix Duo Touch II
the link below will take you to the General Dynamics driver page.
Just select your model and operating system. The WLAN drivers are located in the intel chipset exe as they're the integrated intel ones not a 3rd party
note: windows 7 not supported on Duo-touch II, I had to go back to vista business as I lost funtionality with the buttons and was unable to change resolution above 800 x 600 due to lack of Intel video driver
Oct 08, 2010 | Itronix Duo-Touch II Tablet PC
What graphics adapter upgrade do I need to make
Hi.
The graphic adapter is the video card installed inside the laptop, and normally does not get replaced, as this is integrated with the motherboard.
After installing Windows 7 you will need to install all drivers.
I would recommend using Vista on this laptop, since factory drivers for Windows 7 had not been released. You will have to install general drivers not designed for this laptop.
If you want to install Windows 7 here you get the instructions.
I quote the part concerning video adapter drivers:
"Update the Video Driver
  1. Preparation
    1. Be sure there are no other video drivers installed (you will want to start out with just the standard VGA driver)
    2. Download the latest 82852/82855 drivers from Intel's website
    3. Extract the drivers somewhere, but do not install anything
  2. Turn Off the Digital Driver Signing Check
    1. Create a shortcut on the desktop to cmd.exe
    2. Right-click on the shortcut and select "Run as administrator"
    3. When the command window opens, execute the following commands:
      1. bcdedit /set nointegritychecks ON
      2. bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
    4. Reboot
  3. Install the Video Driver
    1. Open the Device Manager
    2. On the menu, go to Action > Add Legacy Hardware
    3. Acknowledge the initial dialog screen
    4. Select "Install the hardware that I manually select from a list (Advanced)"
    5. Click Next
    6. Select "Display Adapters" and click Next
    7. Click the "Have Disk..." button
    8. Navigate to the path where you extracted the Intel drivers. The *.inf file will be in the Win2000 folder
    9. IMPORTANT: Do not select the 82852/82855 GM/GME drivers, select the 945GM driver (yes, this is counter-intuitive)
    10. If prompted to reboot, DO NOT REBOOT
    11. If told the 945 device might not work right, acknowlege the error, then run Action > Scan for Hardware Changes
    12. "Intel(R) 82852/82855 GM/GME Graphics Controllers" and a "Mobile Intel(R) 945GM Express Chipset Family" devices should now be listed under "Display Adapers
    13. Disable the 945GM device
    14. Reboot
  4. Verify the Video Driver Installation
    1. Upon rebooting, Windows 7 may roll back one or more of your display devices to Standard VGA
    2. Open Device Manager
    3. Check the Display Adapters
    4. If there is only one 82852/82855 GM/GME device, or if there is a new "unknown" device, precisely repeat the above driver installation section (include the instructions for disabling the 945GM device); in the case of an unknown device, run the "Update Driver" action for that device instead of running the generic "Add Legacy Hardware"
    5. When everything is working, you should have "Graphics Properties" and "Graphics Options" menu items in the pop-up menu when you right-click on the desktop
    6. The "Graphics Option" item should have sub-items for display rotation
    7. Reboot and verify that Windows 7 no longer rolls back your display drivers after rebooting
  5. Protect the Video Driver Installation
    1. Go to Control Panel > System and Security > Windows Update
    2. Windows will likely tell you that an important update is available
    3. Click the "important update is available" link (do NOT click "Install updates")
    4. Right-click on the "Intel Corporation - Display - Mobile Intel(R) 945 Express Chipset Family" update
    5. Click "Hide update" from the context menu
    6. If the display driver gets updated to what is currently on Windows Update, the system will revert back to the Standard VGA driver.
  6. NOTE: When using a driver install hack different from the method described here, I have read reports that a system might Blue Screen when using Windows Media Player to play DVD's; however, alternate media players, such as VLC, reportedly do not exhibit this issue. I do not know if this method will have this same problem, but I thought I would mention this workaround in case someone does experience this issue."
You find driver software at Intel Download Center
Regards.
Oct 26, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Is a processor upgrade possible
no, it will not handle a pentium4, but you could get a much faster p3 for it. and the ram amount doesnt depend on the processor type, it depends on the motherboard and os. and it looks like 256 is the maximum ram for that model.
Feb 26, 2009 | Fujitsu Siemens Stylistic LT P-600:...
Screen rotates, pen doesn't
Is it maybe possible it is a hardware prob? maybe the directional sensor in the tablet was displadced.
BTW i have the same tablet and need an harddrive replacement/upgrade, how did you manage to do that? what kind of drive and where to buy? Viewsonic seems not so eager to help me out with that.
Best,
Fredrik
Apr 25, 2007 | ViewSonic Tablet PC V1100
Tablets & eReaders Logo
278 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
