Question about Ricoh Aficio 1035 Copier
SC121 Aficio 1035 Machine come out of this Error code :SC121,now what should i soft this problem,help me ASAP,Thanks.
These are the possible causes of your "scanner error" (SC121). You'll need a tech to solve this:
* SIB or scanner motor drive board
defective
* Scanner motor defective
* Harness between SIB and scanner
drive motor disconnected
drive motor power source
disconnected
* Scanner HP sensor defective
* Harness between SIB and scanner HP
sensor disconnected
* Scanner wire, timing belt, pulley, or
carriage defective
Posted on Jun 15, 2009
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
1035 ricoh aficio printer with error code 322
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Nov 19, 2009 | Ricoh Aficio 1035 Copier
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
409 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
