Question about Exercise & Fitness
How do I regain lost functions on a Reebock RT 5.1 treadmill?
It suddenly started working in manual only and only on speeds above 4. The rest of the control panel does not respond at all.
    Filmmaker:
    Uploaded 5 video answers.
  • 18 Answers
Http://www.manualowl.com/m/Reebok/Competitor-Rt-5.1-Treadmill/Manual/350955 It's look like the engine controller has some fault occurred on it,those board made out of components,as you mentioned motor is spinning but controller not working,so might be liquid damaged through top or faulty circuit refer manual from web ,it's fixable
Posted on Jul 28, 2014
roadtech7
  • 297 Answers
SOURCE: nordictrac 2500 problem: when dead man key is
You have it in DEMO mode, your manual will show you how to disable this feature.
Have a good new year!
Posted on Jan 02, 2011
mnwarfield10
  • 452 Answers
SOURCE: My treadmill comes on, but the control panel is
you req a new pcb (control board) look up your model number on google for spares .
Posted on Feb 26, 2011
  • 5603 Answers
SOURCE: I have a Epic 400mx
Most of these use a membrane keyboard with silver inked conductors on plastic membranes that are pressed together through a hole in an insulation layer between the two printed membranes. When these keyboards start to go bad REPLACEMENT is really the only solution.
Posted on May 20, 2011
ercupa190
  • 12223 Answers
SOURCE: Please any one can send
Dear Sir:
I will help you inmediately.
SOLUTION:
a. Check the reset/off circuit breaker . If the circuit breaker has tripped, wait
for five minutes and then press the switch to the reset position.
b. Make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for
five minutes, and then plug it back in.
c. Remove the key from the console and then reinsert it.
d. Make sure that the reset/off circuit breaker is in the reset position
e. If the treadmill still will not run, you MUST replace the complete PCB to due some electronic component is in ShortCircuit.(Reason for to blown the fuse or c.breaker.
You must provide Mark, Model,Serial Number. please contact the phone number:.CALL TOLL-FREE from the:
1-877-994-4999
www.reebokservice.com
I hope to help you. blessing , sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Posted on Sep 13, 2011
ercupa190
  • 12223 Answers
SOURCE: My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Posted on Jul 23, 2012
Motor runs but nothing happens, belt won't go and no controls work (speed/incline)
Do you have the owners manual that cam with the machine?
Have you checked to see if the walking belt is to tight?
Mar 14, 2015 | Proform 6.0 RT Treadmill
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
Apr 09, 2014 | Exercise & Fitness
Displaying error 1 what could be wrong and how do I repair it?
Apr 09, 2014 | Cybex 44325 Pro 530t Walking Belt X07-07
Proform Treadmill 785 E suddenly stops during highs speed workout
Use 2000W converter instead of 750W because you are using your treadmill on its full power on high speed. 750W converter is not capable of handling its full load resulting the machine malfunctioning. Your treadmill 785E have 2.25 CHP motor, 2.25 CHP is equal to 1677.824712W and 20-Amp minimum Ac outlet is required for your treadmill in order to function in full capacity. Download user's manual on: https://www.sportsmith.net/images/product_support/ProForm/PFTL785081%20-%20PROFORM%20I%20SERIES%20785%20E%20TREADMILL/PFTL78508.1-274823.pdf See Horse Power to Watts Converter on: http://www.rapidtables.com/convert/power/hp-to-watt.htm
Apr 16, 2017 | Proform Exercise & Fitness
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Can you tell me what Err22 is? Thanks!
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Possible Remedies
1. Carefully, vacuum out the drive motor compartment with a static safe vacuum cleaner. Pay
special attention to the area between the speed sensor and speed sensor target.
2. If the motor brushes do not make sufficient contact with the motor commutator, the drive
motor will not start when drive voltage is applied. Replace both drive motor brushes.
3. Adjust the speed sensor position so that the space between the speed sensor and the speed
sensor target is 3/16 inch and so that the speed sensor photo eye is aimed at the larger
portion of the targets wedge shaped section. On hall effect speed sensors (magnetic sensor)
the space between the end of the speed sensor and the flywheel tooth should be 3/16 inch.
4. Locate the speed sensor potentiometer on the lower PCA. Set the speed sensor
potentiometer at mid-range. Start the treadmill and increase the speed to 6 mile per hour.
Carefully adjust the speed sensor potentiometer to the point where the treadmill is operating
the smoothest. Increase the treadmills speed to full speed at repeat the previous adjustment.
These two adjustments are typically small and are usually only a matter of fine tuning.
5. If the speed sensor in inoperative the drive motor will start and run briefly before the error 21
occurs. If it is possible to access the speed sensor wiring, measure the D.C. voltage between
the speed sensor leads Two of the leads will constantly read approximately 5 Vdc. Two of the
leads will toggle between 0 Vdc. and 5 Vdc. as you slowly rotate the speed sensor target. If
you do not see both measurements above, the speed sensor is inoperative and must be
replaced. In some cases the speed sensor is mounted on the lower PCA and the the lower
PCA must be replaced.
6. Substitute a known good lower PCA to determine if the lower PCA is bad.
7. Substitute a known good interconnect cable for the existing cable.
8. Substitute a known good upper PCA to determine if the upper PCA is bad.
Oct 27, 2009 | Precor 9.21 Treadmill
Exercise & Fitness Logo
85 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
