Question about Garden
Position of fuel pipes flymo XLT 3000
Replace fuel lines require position of large and small pipes to carburettor
trippssmengi
  • 76 Answers
SOURCE: Homelite trimmer Carburettor
try cleaning out the cab, with a wire from a loaf of bread stip paper from wire and probe all holes for any debris that could possibly cloging a hole. If that don't work then try a rebuild kit still dont work then you might need to bring it to a repair shop to see if you need a new carb.
Posted on Jan 03, 2009
  • 149 Answers
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Posted on Jan 12, 2009
  • 127 Answers
SOURCE: Replaced fuel lines. How long should the large and
the fuel line with the filter in the tank should go the full length of the
tank
return line 1/2 to 3/4 of a inch in the tank
when changing the one with the filter ,replace filter with new one
Posted on Jun 30, 2009
  • 3567 Answers
SOURCE: Kawasaki EL250 carburettor
Turn off the gas and remove the float bowl. Remove the fuel line. Remove the float pin and float with needle valve. Do not bend the tang that the float needle sits on. Spray carb cleaner into the seat where the needle valve came from to clear out any trash in the valve casing. Spray the float bowl and interior of the carb. Remount the needle and float back in place and put the float bowl back on. Install an in-line fuel filter. The diagram below shows a 1994 carb Yours will be the same or close to it.
A “very helpful” rating on this answer? Thanks!
Posted on Jul 03, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Polan Model 2375 Wild Thing Chain Saw.
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 20, 2010
Testimonial: "Thank you for your help. Your instructions were correct.I did have to reverse the connections on the carburetor. My chainsaw works fine now."
Where do all the pipes go on the Stihl 410 carburettor
One line will be the actual fuel line and the other will be the impulse line that operates the diaphragm in the carb to pump the fuel. The impulse is created by the suction of the engine. I would sugges going to either chainsawr.com or jacks small engines and search your model number for a pdf download on the saw. The blow up will show both lines and where they connect to.
If neither of those vendors don't have a pdf, google search your model number for the same. The info is there. A good suggestion is to make a note of what tube comes off of what port during disassembly and to possibly add to the routine with a number of pics with your smart phone during removal of parts.
May 21, 2015 | Stihl Garden
Flymo xlt 250+ bulb will not pull up fuel what do the two pipes to carb do
The one on the fuel pump side is the main fuel line in. The fuel line should have the fuel filter on it and the filter should sit on the bottom of the tank The one on the metering side is fuel out to primer bulb. Fuel then travels from primer bulb back to the tank
Aug 22, 2014 | Garden
How to fix emission problems ?
Get some Carburettor cleaner spray from an auto center.
Take the pipe off into the air filter unit attached to the Carburettor it normally has a large ring clip around the black pipe so you may be able to use a slot screwdriver or a small ratched driver to remove.
Put a small piece of cloth into the carburettor unit to stop too much contamination going back into the system . Use a cloth or paper towel to wipe off any excess oil inside the carburettor. Spray the carburettor cleaner inside the unit , Using an old Tootchbrush give it a rub to degrease the old oil and fuel. Be careful to Open up the open and closing circular small valve spray a little bit of cleanir inside and using a long piece of cloth clean any contaminated area inside the carburettor.
Dont ruch this and get as much old oil and grease from inside the carburettor as you can. Taking care to remove all the bits of cloth and paper tissue . .
Start the car up with the Carburettor still open to the world.
With the car running and the Carburettor opening and closing spray a little more of the cleaner using the straw in the nozzle into the inside , please make sure you are standing to the side so nothing comes back out into your eyes.
With the carburettor now much cleaner . Put the air pipes back on and take it for a run . At your next fill up of fuel put in a fuel addative for Engine System cleaning and this should help with the emissions.
Jul 20, 2014 | 1998 Volvo V70
Car is fine at norma speeds. Car does not accelerate when you step ******* the gas.
Apr 09, 2014 | 2000 Volvo C70
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
My mini 1973 gts is miss fireing the moment you go over 3000 rpm and i have a huge petrol smell while driving, what can i do?
I'd check the fuel line for holes, splits and bad connections. Then the carburettor, have any of the gaskets failed, is there any petrol leaking. Finally are any breather pipes blocked or disconnected.
Mar 17, 2011 | 2000 Mini Cooper
Fuel is consistantly running out of the (green) drain line at the bottom of the carburator. The bike seems to be running fine, but there must be a valve stuck open. Can anyone tell me how to resolve? ...
THIS IS THE FUEL LINE USED FOR DRAINING THE CARBURETTOR ALSO, MAKE SURE THE SCREW USED FOR DRAINING THE FLOAT CHAMBER IS CLOSED FULLY, IT MAY BE THAT THE FLOAT NEEDLE IS STICKING, OR IT HAS SOME DIRT STOPING IT CLOSING FULLY, TURN OF THE FUEL, REMOVE CARBURETOR, HOLDING IT IN AN UPRITE POSITION CAERFULLY REMOVE THE SCREWS FROM THE FLOAT BOWL, THEN REMOVE FLOAT CHAMBER,(BOWL) ONCE REMOVED MEASURE THE AMOUNT OF FUEL IN THE BOWL, IF THE LEVEL IS CLOSE TO THE TOP OF THE BOWL, WITHOUT THE FLOAT IN IT, OBVIOUSLY WHEN YOU PUT THE FLOAT BACK IN THE FUEL WILL OVERFLOW, IN THE CENTRE OF THE BOWL YOU WILL SEE A BRASS LEVEL PIPE, THIS ALOWS THE FUEL TO PASS OUT OF THE PIPE IN A SITUATION LIKE YOURS, TURN THE CARB UPSIDE DOWN YOU WILL NOW SEE THE FLOAT ASSEMBLY SECURED TO THE BODY WITH A PUSH PIN, YOU WILL HAVE TO REMOVE THIS TO REMOVE THE FLOAT, WHEN YOU HAVE DONE THIS,, CAERFULLY LIFT UP THE FLOAT,YOU WILL SEE A SMALL VALVE WHICH LOCATES IN THE FLOAT, THIS WILL FALL OUT WHEN YOU LIFT UP THE FLOAT SO CARE IS REQUIRED NOT TO LOOSE IT AND NOTE DIRECTION OF FITMENT, I ADVISE WORKING ON A CLEAN BENCH SO ANY PARTS WHICH MAY FALL OUT CAN BE READILY FOUND , ONCE REMOVED CHECK IN THE VALVE SEATING FOR DIRT ETC, ALSO THE VALVE END MAY BE WORN, WEAR TO THE END OF THE VALVE CAN ALSO CAUSE FUEL TO FLOW OUT OF THE DRAIN PIPE, ONCE YOU ARE SURE ALL IS OK REASEMBLE FHE FLOAT AND NEEDLE ASSY IN REVERSE CHECKING THE NEEDLE LOCATES CORRECTLY WITH THE FLOAT, IF YOUR FLOAT HAS A METAL TAB IN CONTACT WITH THE FLOAT NEEDLE, IT IS POSSIBLE TO ADJUST THE FLOAT HEIGHT IF REQUIRED, I WOULD SUGGEST FIRMLY HOLDING ON THE BOWL OF THE CARB ,AND CONECTING IT TO THE FUEL LINE WITHOUT THE SCREWS, TO CHECK IF YOUR PROBLEM STILL EXSISTS BEFORE YOU RE FIT THE CARB, THEN TURN OF THE FUEL REMOVE THE PIPE AND RECHECK THE LEVEL OF FUEL IN THE CHAMBER IN COMPARISON TO THE OVERFLOW PIPE IT WANTS TO BE AT LEAST 5MM BELOW THE TOP OF THE PIPE, SOME BOWLS HAVE A LEVEL LINE IN THEM, CHECK IT OUT GOOD LUCK, LEVEL OF DIFFICULTY ONECE CARB IS REMOVED, 6 BASED ON A 1, TO 10 SCALE
Nov 27, 2010 | 2003 Yamaha TT-R 125
Craftsman 32cc Line Trimmer pull start will not engage engine.
With a flashlight, look into the area just in front of the pull rope. You'll see the fins on the flywheel. Turn the flywheel with a small screwdriver until you see a bracket mounted on it. There's is one on each side. While holding the flywheel still with another screwdriver, spray penatrating oil on each one and work them back and forth a few times. You'll feel them loosen up. They are spring loaded and should snap back into place. Hope you can understand this. Good luck.
May 25, 2009 | Garden
On a Petrol Flymo hover mower where does the clear fuel line go after it leaves the port near the air filter housing?
the fuel line goes from the carburetorport straight to the fuel tank outlet,some have an inline filter fitted to pipe as well so be aware that there could be one which would mean a split in the pipe
Mar 28, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
