Question about ASUS N73JQ-A2 I7-740QM Notebook
Keyboard malfunction Keyboard acts very erratic
Samsung r519 keyboard faulty
luckily keyboards are not expensive ... you either need to have your laptop keyboard replaced OR your num lock may be on causing the keyboard to act erratic and if you find the num lock button and push it that should help
Jul 11, 2014 | Samsung Computers & Internet
QAcer aspire 4730z keyboard unresponsive.
Borrow another keyboard as a test. If wireless, replace the batteries. Check for malware.
Apr 30, 2017 | Acer Aspire 4730-4947 Notebook
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
My memorex mmp9008 keeps saying boot error, shutting down everytime i turn it on
If the unit acts erratically, reset the unit by inserting a thin object (such as a paper clip) into the recessed Reset button. The Reset button is located near the headphone jack. It is a very small hole. This will resest you unit to factory defaults and will help determine whether its a software or hardware malfunction.
Mar 05, 2011 | Audio Players & Recorders
Why would my delete button not work
It's possible that your battery is low if this is a wireless keyboard and mouse. Wireless keyboards start acting erratically when the battery starts to go dead. Replace the batteries and then let me know if that helps.
Feb 20, 2011 | Logitech Computers & Internet
Keyboard acting erratic
The rubber linings inside the keyboard have shifted. you need to open up the keyboard and re allign the rubber padding with the correct keys or take it back to your supplier if its still under warranty.
Jul 24, 2010 | Microsoft (VSM5400013) Keyboard and Mouse
Zboard has issues when I install software
The original drivers are not updated therefore the keyboard acts erratically.
When you just connect the keyboard normally it has the proper driver installed automatically by the Operating systems Dll( dynamic link library ) files You could go to the manufacturer site to see if there is an updated version of the driver or just purchase another keyboard with better compatibility.
Mar 23, 2010 | Ideazon Zboard Keyboard
Keyboard malfunction. i have spilled nothing. i have cleaned nothing. the problem is erratic but it's been at least a week since it started. first the n would only show up every fifth time i struck the...
used the usb keyboard cause you notebook keyboard have sa shorted problem or lost connection.
or go to iBM store ask them if they hav sale a notebook keyboard that's compatible to your notebook computer.. or go to IBM service center let them fix your notebook...
regards
Mar 17, 2010 | IBM ThinkPad T41 2373 Notebook
Keypad not functioning properly...
Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
May 14, 2008 | Acer Computers & Internet
ASUS N73JQ-A2 I7-740QM Notebook Logo
11 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
