Question about Garden
How to remove pump from engine? is there a retainer clip or set screw? devilbiss/excell exh2425 model.
4 Suggested Answers
SOURCE: Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
Posted on Sep 01, 2009
kel1guy2002
  • 3740 Answers
SOURCE: DeVilbiss Pressure WAsher EXH2425 Honda engine
Hi and welcome to FixYa. I am Kelly
Take a look at your engine parts manual here:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/GC160AQHA/gc160%20qha_1.pdf
Watch item 22 and 4 (pdf file page 5) as the engine unloads to see if it is rocking. If it is stuck in one position it will do exactly what you describe.
Also check the 2 springs items 4 and 5 (pdf file page 7.) If one of them is broken it can cause the problem.
What I really think is happening is that the throttle linkage is moving too far and striking the kill switch on the control lever (pdf file page 7) item 14. Watch to see if the linkage is moving and striking the engine stop switch.
Your engine also has an engine fuel pump. Item 1 of pdf file page 19. This pump is operated by the difference in crankcase and carb throat pressure. If any of the hoses are leaking it can cause the fuel pump not to work at low engine speeds and result in engine fuel starvation.
This particular engine is really fussy when the lines get old, crack, or harden. Take a long look at the condition of all of the vacuum, fuel and breather lines.
I can't say that it is the ___ line / hose is causing the problem because there are too many and any one of them can give you fits.
Download the manual... look at the linkages and hoses. I am sure your going to find the cause if you give it a good look over.
Thanks for using FixYa,
Kelly
Posted on Apr 23, 2010
SOURCE: What kind of oil do
Pressure washer oil
I took this picture of my power washer so it's easy to explain the oil.
The oil is different for engine and pump.
The pump oil is 20 or 30 weight non-detergent. SAE20 or SAE30 motor oil. The level of the oil comes up about half way. There is a plastic viewport on side of pump ... oil comes up half way on viewport.
The engine oil is 10W30 motor oil. It comes up about half way or a bit more on dipstick.
To remove oil from pressure washer, do not turn engine on it's side or turn engine upside down or motor oil will run into the carburetor. You might wonder how I know that. Afterward, the carburetor needs to be cleaned out.
To remove oil, you can tip engine to the side but not so much that oil runs up into top part ... to remove the rest of the oil, you can use a plastic hose
Posted on Oct 19, 2010
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
Kenmore Elite HE 4t front load washing machine leaking water bottom right bottom at the end of wash
Unplug the power cord from the electrical outlet. Pull the machine far enough from the wall to get behind it to work
Use a putty knife to pry up and remove the end caps from the control panel. Remove the retaining screws from the control panel with a Phillips screwdriver.
Lift the control panel, and push it toward the back of the appliance. Unplug the wiring harness from the control panel. Remove the retaining clips using a flat-tip screwdriver to release them from the cabinet. Tilt the cabinet of the washer away from the frame, and set it aside.
Remove the pump retaining clips using a flat-tip screwdriver. Pull the pump from the motor shaft. Release the hose clamps using a pair of pliers, and pull the hoses from the drain pump.
Connect the hoses to the new drain pump using a pair of pliers. Place the pump on the motor shaft, and secure it with the retaining clips.
Set the cabinet in place on the washing machine frame, and install the retaining clips with the flat-tip screwdriver. Plug the wiring harness into the control panel. Close the control panel by pulling it forward, and install the retaining screws using a Phillips screwdriver. Install the end caps on the control panel, and push firmly to lock them into place.
Plug the power cord into the electrical outlet. Push the washing machine into place against the wall.
Custom Car Parts
Jun 06, 2012 | Kenmore Washing Machines
Replace fuel pump 1993 mazda 323
REMOVAL & INSTALLATION
323, Protege, 520-22 626 and MX-6 and 522-24 MX-3 Models
See Figures 1 and 2
  1. Relieve the fuel pressure and disconnect the negative battery cable.
  2. If not already removed, depress the clips on each end of the rear seat cushion and remove the cushion.
Fig. Fig. 1: Detach the fuel hoses and electrical connections from the fuel pump, then remove the attaching screws and the pump
Fig. Fig. 2: Exploded view of the fuel pump assembly for the 323, Protege, 520-22 626, MX-6 and 522-24 MX-3
  1. If not already done, detach the electrical connector from the fuel pump/sending unit.
  2. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
  3. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
  4. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
  5. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
  1. Attach the sending unit to the fuel pump assembly and install the nuts. attach the sending unit electrical connector.
  2. Install the fuel pump/sending unit into the fuel tank with a new gasket and install the mounting screws.
  3. Connect the fuel supply and return lines.
  4. Install the access cover and the mounting screws.
  5. Attach the sending unit electrical connector.
  6. Position the rear seat cushion over the floor, making sure to align the retaining pins with the clips. Push down firmly until the two retaining pins are locked into the rear seat retaining clips.
  7. Connect the negative battery cable, start the engine and check for proper system operation and for fuel leaks.
May 08, 2012 | 1993 Mazda 323
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
Does my Honda 5.0 EXH2425 take mixed gas?
No it is a 4 cycle engine and does not use mixed gasoline.
Jun 01, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I need to remove the cooling fan shroud from my 1995 Lincoln Continental. How is the easiest way to go about this?
Engine Fan REMOVAL & INSTALLATION 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the radiator upper sight shield.
  3. Disengage the electrical connector, then remove the integrated relay control/constant control relay module assembly located on the radiator support.
  4. Disconnect the fan electrical connector. Fig. 1: Disengage the fan electrical connector 86873115.jpg
  5. If necessary, remove the air bag crash sensor.
  6. Unbolt the fan/shroud assembly from the radiator and remove. Fig. 2: Unbolt the fan assembly from the radiator 86873116.jpg
    Fig. 3: Remove the fan from the engine 86873117.jpg
    Fig. 4: Slide the fan as an assembly up and away from the radiator. Be careful not to dislodge the mounting stud on the left side. 93143p56.jpg
  7. Remove the retainer and the fan from the motor shaft and unbolt the fan motor from the shroud.
  8. Installation is the reverse of the removal procedures. Tighten the fan shroud retaining bolt to 23–33 inch lbs. (2.6–3.7 Nm). Tighten the fan shroud retaining nut to 71–106 inch lbs. (8–12 Nm). Fig. 5: Constant control relay module location — 3.8L engines 86873118.gif
4.6L Engine
  1. Loosen the fan clutch-mounting shaft from the water pump hub.
  2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
  3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
  4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
    Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage. To install:
  5. Assemble the fan and fan clutch. Tighten the retaining bolts to 15–20 ft. lbs. (20–27 Nm).
  6. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37–46 ft. lbs. (50–62 Nm).
  7. Slip the shroud into the lower mounting clips and install the shroud retaining screws. Fig. 6: Fan and fan clutch assembly — 4.6L engine 84173064.jpg
5.0L Engines
  1. Loosen the fan clutch-to-water pump hub retaining bolts.
  2. If necessary, remove the drive belt from the water pump pulley.
  3. Remove the fan shroud upper retaining screws. Lift the shroud to disengage it from the lower retaining clips.
  4. Remove the fan clutch-to-water pump hub bolts and remove the fan and clutch assembly and the fan shroud.
  5. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
  6. Assemble the fan and fan clutch. Tighten the retaining bolts evenly and alternately to 12–18 ft. lbs. (16–24 Nm).
  7. Install the fan and clutch assembly and the fan shroud.
  8. Install the fan clutch-to-water pump hub bolts.
  9. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
  10. If removed, install the water pump drive pulley and adjust the belt tension; refer to Section 1.
  11. Tighten the fan clutch-to-water pump hub bolts evenly and alternately to 15–22 ft. lbs. (20–27 Nm). Recheck the belt tension.
Jul 14, 2010 | 1995 Lincoln Continental
Water leaking. A small amount of water leaks when
The usual cause of such leak is a damaged or worn drain pump. Replace it to solve the problem. It can be accessed from the back if it is a belt drive machine or from the front if it is a direct drive. Make sure to unplug the machine before servicing.
Cabinet Removal Procedure (Direct Drive machines)
Remove the console depending on the model of your machine.
  1. If the console is secured by screws, simply remove the screws, lift the console up then flip it to the back of the machine. On some models, the screws are hidden under the console's removable end caps. Pull the end caps to the front of the machine to access the screws. If the console is not held by screws, use a putty knife to release the retaining clips under the front corners of the console. Insert the putty knife blade and push it until the clips are released.
  2. Disconnect the lid switch connector from the body of the machine.
  3. The body of the machine is held on to the back panel by two retaining clips. Use a flat blade screw driver and insert it to the lip of the clip and push it to the back of the machine.
  4. Lift the lid and grab the front of the machine's body. Brace the machine's body with your knee, lift and pull it towards you to remove it. You now have the access to the drain pump.
  5. Reinstall the cabinet in reverse order of the procedure above.
For belt drive washers, remove the access panel on the back of the machine to access the drain pump.
Drain Pump Replacement Procedure
  1. Remove the spring clamps that hold the hoses to the pump. Compress the spring clamps and move it away from the pump.
  2. The pump is held on to the motor by two retaining clips. Pry the clips away to remove the pump from the motor.
  3. Remove the hoses from the pump and install the new pump in reverse order of the procedure above.
Jan 20, 2010 | Kenmore 15864/15862 Top Load Washer
How do i replace the fuel pump in my 1993 mazda 626 2.5
3. If not already done, detach the electrical connector from the fuel pump/sending unit.
4. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
5. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
6. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
7. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
Jun 13, 2009 | 1993 Mazda 626
Garden Logo
339 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
