Question about Texas Instruments TI-89 Calculator
Exact same problem with mine :-(
Frozen, only buttons that work are shift and diamond keys.
    Scholar:
  • 72 Answers
Remove all the primary batteries from the calculator, then remove the small round silver battery (you may need to remove the plastic backing) for 15 seconds. If done properly, the device should be forced to hard-reset. If this does not solve the problem, then physical damage may have occurred to the keyboard in the calculator, causing the keys not to function properly. But seeing as it has happened to more than one it is either a software or hardware design flaw that either needs a hard reset or your calculators may just be lemons. Disclaimer: I have not tested these procedures as I may not own the same devices or hardware and am unable to obtain one for reasonable testing or have not personally experienced the same problems with my devices.
Posted on Jun 15, 2009
TI-89 Titanium completely frozen (Tried all reset methods)
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium.
Or, type diamond key simultaneosly with + or -
(plus or minus) key to resolve dark screen.
Jun 01, 2017 | Texas Instruments TI-89 Calculator
The key will not come out of column
When mine does that, the covering on the gear shift button is keeping the shifter from locking. Pull ur car back in gear and put it back in park making sure the gear shift button has released and ur key should come out. Mine does it all the time. The button on the gear shift has a covering on it that is probably lose and wont let the button release all the way.
Oct 21, 2012 | 2002 Pontiac Grand Prix
Where can I find the log values in TI 89
For natural logarithms, you can use the ln function (2ND shift of the X key). For example, the natural logarithm of 3 is 2ND [LN] 3 ) ENTER.
For logarithms to other bases, use the log function (diamond shift of the 7 key). For example, the base-2 logarithm of 16 is diamond 7 1 6 , 2 ) ENTER. If the base is 10 (common logarithms), you can omit the comma and the second argument.
Mar 09, 2011 | Texas Instruments TI-89 Calculator
My shift key does not works. My cap lock does
Try pressing " Fn + Capslock" at the same time. this will realease your shift and release numlock. if that doesnt work try Fn + F11 I cant remember the exact placement of the keys off the top I i do remember is was a Function button combination with the Caplock key to get it back to normal.
Aug 30, 2010 | Lenovo Tablets & eReaders
How to get the exact answer if press enter?
To convert a single answer, press the diamond key then ENTER. To have everything this way, press MODE F2 then scroll down to Exact/Approx and change the setting to APPROXIMATE.
Jun 23, 2010 | Texas Instruments TI-89 Calculator
When powered on, the LCD screen is dark blue.
Press and hold the Control key marked with a green diamond, then press the minus key (above the + ) to lighten the screen. If you lighten the screen contrast too much you can darken it as follows:
To darken the screen press and hold the diamond key and press the + key.
May 29, 2010 | Texas Instruments TI-92 Plus Calculator
I need to access the bios on my A15-S127. Pressing F12 does not work. How can I do this? I cant get The OS to install the harddrive is ok. It will run a Spotmau program. Lee
With power off, hold down 'control' and 'shift' keys, then turn laptop on. While holding those down tap the 'esc' key immediately. 'control'+'shift'+'esc' should get you the BIOS. Does on mine anyhow...exact same model.
Sep 27, 2009 | Toshiba Satellite A15-S127 Notebook
Screen frozen calculator not responding to buttons pressed.
give it a factory reset, this works, you will lose any unarchived data : http://www.associatedcontent.com/video/265/how_to_reset_a_texas_instruments_ti89.html?cat=59
Aug 30, 2008 | Texas Instruments TI-89 Calculator
What keys due i use to calculate a fraction, where is the fraction key
To do fractions, just use the normal divide button.
To see the exact answer, hit MODE and scroll down to Exact/Approx and change to EXACT. In this mode, it will give the fraction always unless you press the special (green button with diamond) before pressing ENTER and it will give the approximate decimal value.
Jan 22, 2008 | Texas Instruments TI-30 XIIS Calculator
Split keyboard & capslock shift function
I had a similar problem and noticed I hit the F Lock button. On mine it was a one way plunger stuck down. This caused the problems you mentioned on mine. Prying it up with a paper clip had my unit working immediately. Good luck!
Oct 30, 2007 | Logitech Cordless Desktop MX 3000...
Texas Instruments TI-89 Calculator Logo
152 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
