Question about Acer Office Equipment & Supplies
Fan failure in acer projector
How do I replace a failed fan in a projector
    Problem Solver:
  • 20 Answers
Take it out, measure it, buy another one, and splice it into the old plug.
Posted on Mar 31, 2014
How to correct the fan on acer projector
Is the fan clogged? If it is then strip the projector down and clean it otherwise replace the fan.
Jul 14, 2014 | Acer X1230 DLP Projector
Fan fail in1110
You should check first the fw version. Tha last fw version is v 3.2.4. if the fw is updated it, replace de fan, if fan is ok, replace ECA controller. InFocus IN1100 Projector
Apr 01, 2014 | InFocus Corp. Open Box InFocus IN1110...
Lamp of benQ projector switched off suddenly and failed to light again,but the power button is ON and the fan is working,so what are the causes and how to solve the problem?
Hi
It seems like the lamp has failed. The cause of this is because the lamp can only run a certain amount of Hours before it will fail completely. On some projector models you are able to view the expected fail date and on other there is a warning light on the projector itself indicating that the lamp has reached a certain amount of hours and failure is imminent. Replacing the lamp should solve your problem and is usually quite easy to do
Kind Regards,
Oct 23, 2013 | Sanyo PLC-400 projector lamp Projector...
Fan fail error. projector shall shut down automatically
If the Fan fails the temperature goes up and so the temperature is detected to be high to cut off the projector.
Please replace fan or correct the power to the fan.
Apr 02, 2011 | Acer X1230 DLP Projector
Projector turns on but says fan failure any ideas on how to fix this problem
Yes.
You will have to find out which of the many fans has failed.
I reckon it will be the fan neaest the lamp.
Clean the air ways and repair or replace the fan.
These fans have a sender unit that tells the processor when they are not rotating.
Take great care when entering the optical block!!!
Hope this helps
Dec 11, 2010 | Relisys RHTP200 DLP Projector
Sony VPL-FE100 Fan Failing
Replace the fan and the fan motor. Most likely it is a internal problem with the fan
Feb 14, 2009 | Sony VPL-ES3 Multimedia Projector
SP4805 Fan Issue
the fans in these models do not have a speed sensor wire to let the main board know to turn off the lamp to not risk overheating. so if the fan goes, the lamp remains on. however, if the lamp exploded, check the vents for dust. there is a temp sensor that will shut down the projector if it gets too hot. if the vents are clogged, blow the dust out of the projector with canned air. the dust keeps in the heat that the projector is trying to expell. easiest way to repair the fan w/o buying a part: splice the fan wires together. they can share voltage. if the 80mm fan does not work at all after that, replace the fan (pn: 526-0192-xx).
Jul 31, 2008 | InFocus ScreenPlay 4805 Multimedia...
Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
327 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
