Question about Emerson LD190EM2 19 in. LCD HDTV
Does not turn on
When I plug in the unit the green light turns on but none of the buttons work
  • Emerson Master
  • 3,320 Answers
What is it connected to?
Posted on Mar 31, 2014
Headset will not re-set according to instructions. Indicator light is half red, half blue. What should I do?
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
Oct 14, 2015 | AUVIO Bluetooth Headphones
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Canon pixma IP2000 not starting
dear,
uninstall the software of your printer and reinstall it...hope it may work.
thanks.
Jun 16, 2009 | Canon PIXMA iP2000 InkJet Printer
Had my laptop plugged in overnight. I turned it on
try to press the power button for more than 10 seconds and try to power it again
Jun 08, 2009 | Acer Aspire One PC Notebook
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
Emerson LD190EM2 19 in. LCD HDTV Logo
163 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
