Question about Dell V525w Wireless All In One Inkjet Printer
Dell V525w printer problem
I am having issues printing text in black. My printer will print the text normally. However immediately above and below the line of text it prints a diminished line of text as well. Does anyone know how to fix this or is it even possible?
SOURCE: Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Posted on Apr 30, 2008
SOURCE: Won't print black
MY DELL 725 PRINT WILL NOT PRINT IN BLACK INK. I HAVE A NEW PRINTER. I EVEN BOUGHT A NEW INK CARTRIDGE AND IT STILL PRINTS IN GREEN ONLY. WHAT CAN I DO TO HAVE MY DOCUMENT PRINT IN BLACK?
Posted on May 28, 2008
SOURCE: Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Posted on Sep 23, 2008
57 varieties
  • 1653 Answers
SOURCE: Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Posted on Sep 30, 2009
SOURCE: dell 926 photo printer will not print black ink.
Nope, not the cartridge...swapped out known good cartridge from our other Dell 926, still the same problem...printer will not print black...both carts work fine in other Dell 926
Posted on Apr 01, 2010
Why does my dell printer yellow in the area where red should be?
Probably not getting red ink. You should chek the level of your red ink. Also the cartridge mighbe be obstucted. Install a new red ink cartrirge
Nov 22, 2014 | Dell V525w Wireless All In One Inkjet...
My printer is not printing anything on paper but I have ink it is only printing yellow when I did deep cleaning and cleaning and alinment could it be printer head
Are you sure you have ink? If you refilled recently and you are supposed to have ink, your printer head died and there is no way to prin with it. You mus to get a new one
Oct 13, 2014 | Dell V525w Wireless All In One Inkjet...
Dell printer won't print and comes up with the message printer in error state
Hi Richard,
Is the printer connected via a USB cable directly to your computer, or are you using a network cable?
Apr 18, 2014 | Dell V525w Wireless All In One Inkjet...
My Canon MP560 won't print black
I have problem with my canon IR 2420 DISPLAYING E000007-0000
WHAT CAN BE APROBLEM
Nov 17, 2013 | Canon MP560 All-In-One InkJet Printer
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
Very fine horizontal black lines superimposed over text printing.
Print at a higher resolution. Clean the print heads, check the print alignment.
May 15, 2009 | Dell 922 All-In-One InkJet Printer
DELL 3000cn Printing Problems - Black text is very light
It sounds like the font that is being used is too light, not dense enough. Is there a default density or toner save function on this printer? Check the settings from the control panel.
Jan 26, 2009 | Dell 3000cn Laser Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Laser printer problem
For starters aftermarket cartridges are just not like the new ones from Dell. I quit using aftermarket ones long ago to save these headaches, with Dell you can get on Dell Chat and they will gladly help with issues like this. Try that with "Bob's Printer Cartridge and Music Rental" you won't get anywhere.
Mar 13, 2008 | Dell 3100cn Laser Printer
Dell V525w Wireless All In One Inkjet Printer Logo
119 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
