Question about Elation Stage Setter 8 Dmx Controller
Connecting stage setter 8 to computer
I would like to connect Elation Stage setter 8 to a computer to be able to control the lights with a program.
I have four 200b lights that i must have connected to a wrong device and all 4 blew fuses. I replaced the fuses but they continue to blow as soon as I plug them in.Any suggestions would greatly appreciate.
first need to know if the other device you connected it is with dmx and if not, the most likely need replacement on the circuit 8 pin controller dmx its easy to know the locate its the circuit most close to the input signal, I hope you test the input volt regulators and are well, if not also need more data presents fault.
Feb 16, 2013 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor...
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
Jun 24, 2011 | Behringer Active 150Watt PAMonitor Speaker...
The fuse blew, can't read what the ampage is
This doesn't compute as there is no fuse external to the unit and it runs off a 12 volt wall wart supply. The supply is 500ma or more. Any INTERNAL fuse would probably be rated at that or slightly higher like 650 ma or even 3/4 amp. If the internal fuse blew it was for a reason... using wrong adapter probably would do it... Other than that take it to a competent repair shop as the fuse will probably blow instantly again. This appears to take 12 to 20 volt 500 ma minimum wall adapter with CENTER positive, unlike many devices. If you put wrong polarity adapter that would probably blow the fuse and MAYBE another component.
Apr 26, 2011 | Elation Stage Setter 8 Dmx Controller
Where do you connect wires from mixer to stage monitors
Judging from your mixer, I would connect your stage monitors to your SUB outs. Your mixer has 4 of them, allowing you to make 4 separate mixes to 4 monitors.
Mar 24, 2011 | Behringer XENYX 2442FX Mixer
StageSetter 8: when the power switch is turned on the internal fuse blows immediately.
Likely the filter caps or the rectifier diodes have shorted. Power supplies are easy to work on unless the are switching type.
To work on this, replace the fuse and put a 25 watt light bulb in series with the hot side of the inout power... saves fuses and will send enough current in to troubleshoot with a meter. Use SAFE procedures when working on electrical equipment. For switching power supplies you need to use a line isolation transformer for personal safety.
Mar 14, 2011 | Elation Stage Setter 8 Dmx Controller
I Have mackei fx 8 i use to connect 2 main via the main baleced outputs. i am planning buy a stage monitor bou not sure how make a connection for monitor
Buy a powered stage monitor and gonnect to the MON jack. You will select the channels to go to the monitor with the AUX knobs and the overall level with the MON slider.
Use BALANCED lines to the powered monitor... This is a TRS plug at the mixer end for sure...
REMEMBER to power ALL interconnected equipment from the same receptaacle or source, even if it means running an extension from where your speakers are plugged in to the mixer !!! The ground bounce between power receptacles within a building can destroy your equipment's sensitive input circuits.
Dec 18, 2010 | Mackie ProFX8 / SRM450 V2 PA Package
I need schmatics for my Chauvet ColorBank 8 stage lighting system
seems as thou the Color Bank 8 stage lighting system is a fixture....what controller are you usein?
Jun 20, 2009 | Music
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
Lacking volume
We used canned air to blow dust from the volume control slider connection. It did increase the volume, not quite to the original level, but to an acceptable level.
Dec 05, 2008 | Music
Elation Stage Setter 8 Dmx Controller Logo
29 people viewed this question
Top Elation Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Elation Music Expert? Answer questions, earn points and help others
