Question about Car Audio & Video
Low level fuel light came on with 3/4 tank full. guage reads fine just light on.
2002 holden rodeo ute, low level light came on with 3/4 of a tankof fuel. gage reads fine.
  • wayne c Apr 02, 2014
    really there is nothing more i can add. i stasrted the ute as usual and the low level light came on. the fuel gage still reads correctly at 3/4 tank. i opened the filler cap and reinstalled it. started the ute and still the light is on. no other problems show in the engine performance otr while driving. just that light is on,.
    Problem Solver:
  • 11 Answers
Either the gauge is broken and the fuel actually is low or the fuel level sensor on the pump in the tank is broken or stuck consult a professional shop
Posted on Apr 02, 2014
  • wayne c Apr 03, 2014
    thank you. i will go the next step and remove the unit and check it out. thank you, will respond with results that i find. thanks again for your assistance.
I have a 2002 lincoln ls that has gas guage reading only a quarter tank when full. I know there is 2 pumps on this car, one is the primary pump under passenger back seat and a jet transfer pump on drivers...
Fuel pumps outside the gas tank have nothing to do with fuel gauge readings. There is a fuel level sender unit inside the tank with a float which supplys variable ground circuit to the gauge. If you can find the wire to this unit, you can ground it to see if the gauge now goes to full. If so, sender unit in tank is bad, or has bad wiring/ground.
Jan 30, 2015 | 2002 Lincoln LS
Why can't find water trap on rodeo second generation TF 1988 2003 Holden rodeo tray top
Not unless it was fitted after market. to make sure trace the fuel line from the fuel filter back to the tank.
Jul 08, 2014 | Holden Rodeo Cars & Trucks
Low fuel light on gauge doesnt work
lamp burned out, ?
but does the fuel guage work 100%
and at what tank level do you expect the lamp to come on.?
did you read the FSM on this, its covered
or alldata.com?
free.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
on this car, the PCM reads the fuel level then sets the fuel guage
and if the level (voltage from tank sender) is below a specific
voltage , it glows the lamp, low fuel
so if the fuel guage works, and the lamp is dead, the lamp is burned out. (or conn. bad to it)
Jan 24, 2014 | 2002 Jeep Wrangler
Engine will not start after changing battery in 2004 Isuzu Rodeo
Get yourself a can of starting fluid spray, and spray NO MORE than a two second burst into the air intake after removing the filter. Then crank it. If it fires (very briefly), your problem is low or no fuel delivery to the engine.
May 16, 2017 | 2004 Isuzu Rodeo
What does it mean when the little gas tank flashes in my dashboard?
You are low on fuel. Your gas guage may be broken.
Mar 15, 2011 | 2001 Isuzu Rodeo
Fuel gauge is on empty and the low fuel light is on, but the tank is full
u either have a bad level sensor in the tank or the guage is bad. u need to get wiring diagram and find connector for fuel sending unit and jump wires to trick guage into thinking it is full if it still say empty u need instrument cluster if it goes to full it level sensor in the tank
Feb 23, 2011 | 2002 Saturn VUE
I have a 1996 holden rodeo ute petrol and it wont idle
I had the same problem, I changed everything, air flow meter, plugs, leads, checked the timming belt etc. etc. The problem turned out to be the fuel pump, its inside the tank, you need to check the fuel pressure with an inline guage, it needs to have 30 psi, mine was only 15 psi. also you should have the injectors cleaned. good luck. Gary
Oct 18, 2010 | Isuzu Rodeo Cars & Trucks
Fuel problem holden rodeo ute 1994 is not starting beleave it could be the fuel pump. Remove line no fuel coming out belreave that the pump is beside fuel tank drivers side of vehicle
In that year of vehicle I wouldn't be surprised if the fuel pump was in the tank. I would be surprised if it was not in the fuel tank.
Jul 05, 2010 | 1994 Isuzu Rodeo
Car Audio & Video Logo
143 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
