Question about Dual Electronics XDVD710 Car DVD Player
The screen lights up only for a second when comes out then goes blank any suggestions
Screen goes blank after about a second
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Apr 16, 2009 | Computers & Internet
Blank grey screen appears for few second & goes.
hi..thats the problem in your phone.So take the
phone to the service centre with your warranty
bill.
check it out..
thank u..
rate me..
Feb 13, 2009 | Sony Ericsson w580i Cellular Phone
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Cell phone (Sony Ericsson W910i) turns itself off every 30 seconds
i have one too and it always turns itself off at least 15 times a day and a red light comes on at the back and the screen is blank. It hangs up on people half way through phone calls, and tells me i have messages wich i don't and comes up with blank messages which i can't delete!! Today it has done the exact same thing again but it has been frozen for over 3hours i have tried taking the battery out and nothing works :(
Feb 26, 2008 | Cell Phones
Dual Electronics XDVD710 Car DVD Player Logo
26 people viewed this question
Top Dual Electronics Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
xxxxxx xxx
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
