Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Jacuzzi toilet fill valve debris filter removal
Debris filter clogged, and water will not go onto tank
tbirdfan1
  • 3051 Answers
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Posted on Sep 13, 2009
al_kupchella
  • 843 Answers
SOURCE: The toilet fills slowly, 35 to 45 sec even though
There usually is no filter, but the holes in the float valve can be pretty small. You should probably take the valve apart, but I can give no specific advice on this since there are lots of different kinds of float valves. It is possible that there is a screen where the float valve sticks through the bottom of the tank (but this is part of the float valve assembly) You also might have large piece of debris trapped in the shut-off valve. Turn the water off at the main to work on that one - but don't bother with this unless cleaning the float valve doesn't fix it.
Posted on Jan 20, 2010
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
Posted on Jul 19, 2010
woobie dog
  • 1273 Answers
SOURCE: my jacuzzi toilet doesnt fill with enought water
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Posted on Jan 29, 2011
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
Tank takes a long time to fill
check for a clog in the toilet valve supply as the washer can deteriate or the old piping in the house can clog if they are old and made of galvanize pipe or the fill valve is clogged. replace valve and or fill valve in the tank
Aug 03, 2013 | Jacuzzi Home
Tank take 0ver 10 mins to fill
What about sand? There may be a screen in the filler that is dirty and needs to be cleaned.
May 11, 2013 | Jacuzzi Bath Perfecta EZ33 959 White round...
Jacuzzi toilets installed one year ago - for the first year toilets filled up in a matter of seconds - now both toilets are taking up to 4-5 minutes to fill up the back tank. nothing has changed - why...
sounds like you may have debris in your lines. I was not aware of this until recently but, you should drain your water heater once a year to get rid of sediments that linger and travel through your lines causing possible blockage problems. Try turning your water valve off. Flush toilet so there is no water in the toilet or tank. Unscrew your line to shut off valve to make sure there's no debris. Good Luck!
May 18, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Jan 29, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
The toilet fills slowly, 35 to 45 sec even though the service valve is wide open. I suspect that trash in line has clogged the filter (we had a recent problem with other fixtures after the water company...
Jan 20, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Toto CST853 cistern will not refill. Was fine yesterday. City is working on pipes and broke a water main last evening, all other faucets and toilets are working....can I clean the water filter or does it...
alot of times you can turn the water off to the toilet and the tops of the fill valves usually pop or screw off. then if you put a small cup over the top of the fill valve you can turn it back on and flush the debris out and put it back together. if its a fluid master type you can pop the top off it. and turn the float arm a 1/4 to half turn and the whole top will come off
Jul 31, 2009 | Toto Aquia II Dual Flush Toilet
Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Mar 11, 2009 | Home
Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Mar 09, 2009 | Toto Drake ADA Compliant Toilet with...
I have a toto toilet. After flushing it is taking a very long time to fill up.
Make sure that the fill valve doesn't have debris caught inside near the valve needle. Also the tube that attaches onto the flush valve can become clogged near the fill valve as well. Remove the hose and then take a needle and try and clear the outlet. Blow through the tube to insure that it's not blocked as well.
Mar 07, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
124 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
