Question about Samsung WA50F9A6DSW Energy Star 5.0 Cu.Ft. Top-Loading Washer with Aqu
Will not start cycle
Just purchased washer, plugged in and hoses are hooked up...no water going into washer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 61 Answers
Sounds silly, but are the taps turned on? Also, make sure there are no kinks in the hoses. If this doesn't solve the issue, the inlet valve or the control circuit may be bad. If this is a new washer it may be covered by warranty.
Posted on Mar 31, 2014
When my Kenmore machine is running on the wash cycle warm/warm no water is coming at all. I could run the machine only with cold water even on the cycle warm/cold.
Most likely the hot water hose is plugged up, or least likely, the hot/cold valve is broken or plugged up.
Find a large container, or better yet, hook up a garden hose that you might try the faucet where the hot water is hooked up and see if water will come out of it when the washer hose is not hooked up there.
If it will not, you have a plugged up hot water pipe or the water heater shut off valve is closed.
If you get good water pressure and hot water from the faucet, look at the filter screens that are inside the ends of the hot water hose and see if any are plugged up.
There may be several.
If not, perhaps the inlet water solenoid has failed. That plastic part is where the hoses attach to the washer itself.
God bless your efforts.
Jan 22, 2016 | Kenmore Washing Machines
Leaking maytag neptune washer
The pump and its various hoses are easily accessable through the back panel. The boot can collect coins which can block the pump. Squeeze the boot and empty it of all coins. Coins can ruin the impellers on the pump. A new pump costs $100 on line. The drain hose can be plugged by dimes and pennies. Good luck.
May 28, 2014 | Maytag Neptune MAH5500B Front Load Washer
AFTER RUNNING AWHILE MACHINE STOP & MAKES A BUZZING SOUND.....STARTS UP AFTER 30MIN....NOW IT DOESN'T RESTART JUST MAKES THE BUZ SOUND..WHAT SHOULD I TEST, OR WHAT....
Sounds like one hose is turned off or plugged. The buzzing is ususally the inlet valve without water going to it.The machine will wait forever. Verify that both hoses have water on and actually flowing.
The typical situation is the hoses get hooked up backwards, but both are turned on, no one notices.....Dad gets big hot water bill, and turns off hot water (routed to cold inlet valve) Washer uses hot or warm until rinse cycles (which need cold water, which dad turned off).... Machine gets halted waiting for water....
Feb 13, 2011 | Amana Washing Machines
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Washer wont take water. When start it will go to wash cycle. I have to get a water hose and fill it before washing
you might check the water inlet switch this is where the water hoses hook up you have to take off the front cover I don't know what make of machine this is or I could help you get to the switch. Before you do anything take off the hoses from the back of the washer and check to see if the screens are clean or clogged.
Jun 23, 2010 | Washing Machines
What hose do i hook up to the sink in order to start the wash cycle the black or grey or both?
If the washer has 2 seperate hoses, then you need to connect both hoses, if only 1 hose, then hook up tp the cold water supply.
Pl;ease leave feedback.
Thanks.
Nov 15, 2009 | Malber WD1000 Front Load Washer/Dryer
S1600 pulsating on and off at about 10 sec intervals
Nozzle is plugged. Clear with small diameter wire thru Nozzle
Aug 31, 2009 | Karcher Garden
Aggitator operates as soon as the washer is turned on.
Your pressure switch hose maybe be plugged. This is happening because your washer thinks it's full of water.
Remove the clear hose from the pressure switch behind the control panel and blow through the hose. You are basically going to blowing air through the hose and into the wash tub. This will clear any restriction that is in the hose.
This is a common problem and a simple fix for your issue.
If you have anymore questions about this please ask. I will be more than happy to help you further.
Thanks
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Leaks water from soap drawer
could be a loose hose to the drum from the dispenser or a tape still in the dispenser not taken off.
please check it.
tnx 4 using fixya,
drcool
Oct 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Samsung WA50F9A6DSW Energy Star 5.0 Cu.Ft. Top-Loading Washer with Aqu Logo
50 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
