Question about Living Solutions Hot Pot
Was filling up my pot with water in the bathroom sink, and water overflowed and the bottom of the pot was emmersed in water for a few seconds.Will it be unsafe to plug it in now?
Will I get electric shock now if I plug it into an electric outlet?
  • 39 Answers
Make sure it is completely dry and it should be okay but if it continues to do that you masy want to contact Tech support
Posted on Mar 31, 2014
Dishwasher filling up with water
A lot depends on how the drain hose is connected to your sink. I have included a typical connection diagram. It's for a Maytag, but the installation can be for any brand. If yours uses an air gap then I suspect it is defective. Any other connection method would indicate a slow drain.
http://www.homedepot.com/catalog/pdfimages/2e/2e978368-bfef-42c3-a1b3-7591ab282464.pdf
Jun 11, 2016 | GE Dishwashers
How do I get rid of the soap suds coming out of my new bathroom sink overflow (the hole at the front of the sink)?
Your sink drain is partially clogged below the overflow drain so suds laden water is backing part way up that tube discharging suds out the overflow opening.If you have a push-pull built in stopper that's probably holding up a clog just below. Clear the clog, soap suds act like they should.
Nov 05, 2014 | Cars & Trucks
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
My drain pipe has a leak
Tighten all connections first and see if you have a problem. If you still have the leak, then dry the piping under the sink (using a towel) from the sink downwards. Then fill the sink with water and then get under the sink and open the drain. Use a flashlight and feel for moisture with your hands. Start at the bottom of the leak and work your way upwards until you find the area where the leak is occurring. Often leaks appear to be at the bottom of the pipe but the leak can occur as high as the sink drain seal. Be sure to check the back of the piping for leaks. Once you find the leak, you can then determine the course of action to repair the leak.
Dec 29, 2009 | Home
Need to fill resivoir how much
Unplug coffee pot, empty over sink, turn on to ensure it has pumped all water out, turn off, refill with water, restart normally.
Sep 05, 2009 | Krups FME2 Coffee Maker
Water keeps running into dishwasher causing overflow
I had a diswasher with thils problem several years ago. The problem was wiith the plastic float at the bottom. It had hardend greese buildup that kept the float from moving freely. Removing the float and cleanning fixed the problem.
Jan 29, 2009 | KitchenAid Dishwashers
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Living Solutions Hot Pot Logo
74 people viewed this question
Top Living Solutions Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Living Solutions Kitchen Appliances - Other Expert? Answer questions, earn points and help others
