Question about TurboChef TORNADO Electric Oven
Turbo chef tornado f3 smoke and bad smell
I bought a tornado used at an auction. It had been working until it let out a puff of black and gave an f3 error. It smelled really bad. Could this be a blown transformer? The f3fuse doesn't seem to be blown. I assume I would see a black mark on the fuse. I put an amp meter on the brown wire and it didn't show any amps. What should I try next to narrow down the problem?
  • 128 Answers
Transformer burn ? Replace it including capacitor.... Call the technician to do it... Let him check micro switch along also especially the primary....
Posted on Dec 08, 2014
  • 979 Answers
James 938 hit the nail on the head. These ovens are very good and tend to be maintenance free, however, when it does have a problem, it is an unusual one. Good luck and let us know how it does.
Posted on Mar 31, 2014
  • 15 Answers
SOURCE: F3 FUSE BLOWING
If this is a C3 there is only one mag, F3 is the inline heater circuit fuse,
so it is a problem with the heater circuit, the older type heaters are an open coil type the ceramic mouting points can crack and break causing a short as the heater starts to heat, they are also susceptible to damage from oven cleaners. 208 volt units usually draw approximately 23amps when operating properly
Posted on Apr 29, 2010
  • 75 Answers
SOURCE: I have a turbo chef c3 the manual says 240v 30 Amp
240V 30amp outlet your good
Posted on Nov 13, 2009
  • 6 Answers
SOURCE: TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
Posted on Oct 26, 2010
  • 75 Answers
SOURCE: F3 code I have replaced 2 high voltage
holy **** that was a very expencive fix huh. I hope you spent the 50 bucks and have a service manual. What about the diodes, have you tested or changed those. That looks like the last thing i would change and there only a few bucks so i would change them at this point anyway. Are you blowing a fuse at all.
You need to narrow the problem down, not just toss money into the toilet replacing good parts. If your reading 15.1 amps then you have no problem in the high voltage system. Unless the amps are ramping or erratic. Your I/O board is bad if its reading 15.1 and triggering an f-3 fault. You said you replaced it though. Contact who you purchased it from and see if they will help. Its a $420 board and $160 for each HV Transformer they should help. I would guess that your I/O board it bad. You also said you changed relays. Did you change the K2 relay.
Hope you can solve the problem quick. Hopefully this helps
Posted on Nov 05, 2010
richroth
  • 9472 Answers
SOURCE: f 3 mag error. had a bad magnetron and hv
F3 errors can indicate a mag problem. Did you replace both mags? It can also be a door switch. If your fuses are good, you need to inspect the 2 magnetrons. If you have a burned tip on one the waveguide and waveguide cover it will need to be replaced.
Posted on Feb 05, 2011
Tornado turbo chef Oven give f3 fault after16 secs
the most complicated error for this oven ... this error affects ur micorwave system .... this requires a tech to check ur unit
Sep 05, 2014 | TurboChef TORNADO Electric Oven
F3 mag error. can it be the waveguides.
What is your amp draw? You could just have a bad I/O board.
Oct 02, 2012 | TurboChef TORNADO Electric Oven
I have a turbo chef oven, I have F1 and F5 error on the display! Any suggestion?
Troubleshooting...
Faults Requiring Service Call
If one of the below faults appears on the oven display, call 800-90TURBO (88726) or +1 214-379-6000.
* F1: Blower
* F2: Low Temp
* F3: Mag Curr
* F4: Monitor
* F5: Mag Temp
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | TurboChef TORNADO Electric Oven
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
Gettinng message ''F3 mag''
Hello. "F3" is definitely the mag circuit, but not necessarily the magnetrons. Since you heard something "blow", I would be more inclined to look at the capacitors, and the rectifiers/diodes. It is possible that either of your HV transformers, or the preheat transformers has blown also, however, they would have smelled really bad and emitted a bit of smoke, which you did not mention, so I would go for the cap, diode first. Do you have access to a multimeter, and know how to use it? and just a word/warning. You are dealing with High Voltage components, that can/will kill you in an instant if not handled, or tested properly. If you had someone replace the Magnetron before, I would call them again, as they will most likely have what you need on the truck, or be able to get the correct part quickly. You could also call Turbo Chef, maybe they will sell you the parts you need, just remember there are 2 of each in there, so determine which one you need. There will probably be signs if it blew, of burnt plastic near the diode, which is under the cap. A capacitor will have a metal can, probably one will be out of shape near the top where the wires attach, you can look if you want, just unpug it please, and use a insulated screw driver to short the two termminals of the capacitor.
Hope all that helps, and thank you.
Apr 10, 2009 | TurboChef TORNADO Electric Oven
F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
OVER HEATING
Hello. If the SSR is closed, and the oven is off, then the SSR is bad. You can call turbo chef for a part supplier,if you are able to replace it yourself, at 1800 90turbo.
Dec 16, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
264 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
