Question about RTO PasLode 900420 Impulse Framing Nailer
Driver blade stick has snapped, where can i get replacement and how much would one cost. Part No 900420
Piston driver has snapped and I need a replacement. Don't know where to look and how much one would cost
  • 42 Answers
Phone the company they will tell you where your nearest dealer is that could supply a spare part. If you state the model number ( I don't have access to part numbers at present) I could inform you how much it would be from the company where I work.
Posted on Apr 11, 2014
Can I ger instrctions on how to put a blade on my electric clippers?
Most common problem is the mounting tongue snapping shut leaving you nothing to mount the blade on. If the tongue is not sticking out so you can put the blade mounting into it then stick a screwdriver behind it and make it come open. The tongue is a flat piece of metal at the front with 2 lines pressed into it. When it is hanging out pop the blade onto it, turn the motor on and snap the blade shut forcefully.
Feb 17, 2015 | Oster PowerMax 2-Speed Clipper Kit
Staple jams by driver blade in gun and I have to dismantle nose to get it out. Empire Rainco 7-16.
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Mar 06, 2011 | Nailers Empire Rainco R16 Stapler Driver...
The nail gun is sticking ever shot and will not reset
Driver not returning to top of cylinder is caused by several issues. Bent driver, piston oring, and check valve. Remove head and pull out driver. The blade should be straight with no missing pieces. Driver piston should fit snuggly into cylinder and not drop down cylinder under its own weight. If driver / piston look ok, pull out cylinder and look for check seal in place. It looks like rubber band and fits in groove with row of holes. Parts are available at www.toolpartsdirect.com
Sep 18, 2010 | Porter Cable FactoryReconditioned DA250BR...
The brakes are sticking on the drivers side of my 04 chevy cavalier...how can i unstick the brake?
since your complain is on the driver side sticking brake, so i do not suspect that the failure in on your hydrovac, it could be the that your driver side brake caliper piston needs seal kit replacement thats why when you press the brake and when you depress it the piston doesnt retracts. you need to remove the driver side wheel and remove the brake caliper assembly, take off the brake pads, press the brake till the piston comes out, inspect the piston condition and change it if damage along with the seal kit. make sure to bleed the brake before driving the car to release presence of air in your brake system.
May 06, 2010 | 2004 Chevrolet Cavalier
Will the paslode 900420 discharge two nails at the same time.
Stick with the paslode brands nails... the money you save using other brands is off-set by higher maintenance costs and tool down-time
May 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
The pin that fires the nail sticks and won't retract after firing. You can push it back in after it fires, but that is very time consuming. tried cleaning and oiling to no avail.
please go to paslode.com and take a look at the gun's schematic. you have one of two possible problems. check the compression on the pin's piston( it should have 2 metal rings) put the piston at the top of the chamber and let it go , if it drops by itself you may need new metal rings. the other fix is to replace your reed valve( it kinda looks like a comb with four fat teeth) sitting right under your muffler
Feb 10, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Piston will not retract fully once fired
sounds like the tool needs to be cleaned and serviced or the driver is bent, if you don;t have the owners manual to clean this tool, go to Paslode.com and type in your model number for a detailed instruction on the cleaning of the tool.
Jan 14, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
54 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
