Question about Dell Computers & Internet
Full speed unlock key
No problem
How to lock and unlock a Jazzy 1113 VSI?
1. With the VSI powered on, press and hold the on/off key. After one (1) second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
Jun 18, 2014 | Quickie Wheelchairs Auto Sunrise Med...
Unlock the controller
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your powericon1.png chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speedicon1.png/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
Mar 16, 2014 | Pride Mobility Products Jazzy 1170 XL Plus
When i push power button on lights blink constantly, wont move
For future reference, here is the is a procedure for
To lock the VSI:
To unlock the VSI:
Mar 16, 2014 | NRS Hoveround MPV 5 - Used Power...
Can i lock the controls on my jazzy 1121
This is taken from the owner's manual from the 1121 with a VSI controller:
I suggest you print this out and keep it handy.
lock your power chair to prevent unauthorized use.
To lock the VSI:
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Jul 01, 2012 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Forgot how to unlock power chair
This is the procedure to unlock the controller on a Pride Jazzy:
To lock the VSI:
To unlock the VSI:
Jun 30, 2012 | Pride Jazzy Select 6 Indoor Power...
Unlock a lock-out control panel for a jazzy 614hd
To unlock the VSI:
Hope this helps
Apr 12, 2011 | Pride Mobility Products Health & Beauty
Replaced batterys in jazzy chair speed indicator keeps blinking - no code for it - plug in charger works for a minute after unplugged but then goes back to blinking?
Jazzy is in lock mode try the following to unlock:
Lock Mode
To unlock the VSI:
Hope this helps
Mar 29, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Speed lights flash and machine will not run
Hi patriped,
Sometimes we lock our joystick by mistake.
Here is how to unlock it.
If this dosen't fix the problem you may have a bad joystick. Write me back for more info if thats the case.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Jan 27, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Computers & Internet Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
