Question about Fujitsu ScanSnap S510
Power will not stay on
Power on problem.scanner will power on when the scanner lid is opened, but after about 30 seconds it will shut down.
  • Chip Hirata
    Chip Hirata Apr 02, 2014
    Thanks, but I figured it out.
Why when my wifes sled overheated @ idle, will only stay running 30 seconds,keeps shutting down,will keep starting up and the that process starts again, 30 seconds,shuts down
first of all you need to know the year make and model of the vehicle you're talking about and exactly what is the real problem is it overheating I will not stay running
Mar 06, 2015 | Cars & Trucks
When I open the notebook the power comes on then shuts off. when I open the note book all the way up it stays on
Click "Start."
Click "Control Panel."
Click "Power Options."
Click the "Change What Closing the Lid Does" hyperlink on the left side of the screen.
Click the "Closing the Lid" drop-down menu. Select either "Sleep," "Hibernate" or "Do Nothing." All three of these options will stop your Acer laptop from shutting down completely when you close the lid. Click "OK" to save changes.
Oct 11, 2013 | Acer Aspire S7-391-9886
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
The screen is blank but notebook is running
Try pressing the [Fn] + [external monitor] keys on the keyboard, that should switch your computer to the right monitor setting.
If that doesn't work,
1) Power off your computer.
2) Open the lid to about 30 degrees, just enough to reach the power switch still.
3) Leaving the lid partially open, press the power switch to power it up.
4) After the operating system is running the lid can be opened completely.
If you are still having troubles, unplug the power cord, remove the battery pack, then hold down the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. After doing this, shutdown your computer and put the battery pack back in.
Hope this helps!
Email me if you have any other problems,
g33kg1rl7@gmail.com
Feb 12, 2010 | Toshiba Satellite A75-S229 Notebook
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Canon NP 6230 copier - what does error code e244 refer to?
you have a scanner or lens problem look in the glass when you turn it on both the scanner and the lens should move some
Jan 13, 2009 | Canon NP 6230 Copier
Fujitsu ScanSnap S510 Logo
41 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
