Question about Rival Pil-Hc09112 Coffee Makers
Would like to find a permanent filter for my rival rv676 coffee maker.
Would like to locate a permanent filter for this
3 Suggested Answers
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Does the Rival Premiere Dual Travel Mug Coffee
you can get number 4 filters for regular coffee
or use pods
Posted on Jul 29, 2009
SOURCE: Rival Coffee Maker #PIL HC10106 Instructions
lost measuring spoon for pil-hc10106 what is the equivalent amount?
Posted on Aug 11, 2011
Looking for paper filters for kitchen selective one cup brewer
You don't need paper filters it has a 'permanent filter'. That means it has a fine mesh nylon filter that you rinse and re-use.
Kitchen Selectives Single Serve Coffee Maker Permanent Filter Mug Included
Nov 28, 2015 | Kitchen Selectives Coffee Makers &...
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
Rival Coffee Maker #PIL HC10106 Instructions how to program coffee maker
Apr 02, 2011 | Rival Programmable 12-Cup Coffee Maker
How to set the timer
You can download the manual direct from Rival
http://www.rivalproducts.com/product.aspx?pid=2404
This model does not have a timer listed as one of its features.
RivalĀ® 12-cup Coffee Maker FEATURES:
  • Brews 12 (5 oz.) Cups
  • Removable Filter Basket
  • Easy Pour, Non-drip Carafe with Ergonomic Handle
  • Water Level Indicator in Tank
  • Pause 'n Serve Function
  • Convenient Cord Storage
  • Non-stick Warming Plate
  • English & Spanish instruction manual
Mar 07, 2011 | Rival Programmable 12-Cup Coffee Maker
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Sep 17, 2009 | Keurig B70 Coffee Maker
Looking for a permanent filter for a keurig coffee maker
Hello sunflower012,
When I need accessory parts, I do a search on Amazon with model number, name and permanent filter, in your case, for Keurig .
Hope this is helpful to you! Positive feedback is appreciated. Kind regards, NormanZ
Jul 03, 2009 | Keurig Coffee Makers & Espresso Machines
Permanent coffee filter
Hopefully this should help
option 1 http://www.abtecparts.com/hamilton_beach_coffee_filters.htm
or option 2
1-800-851-8900 HB customer care
Thanks and please rate me!
eric
Dec 07, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
MR. Coffee ARX23/ARX20 permanent filter
8-12 permanent filter...i also came across that "MR. COFFEE® brand" is a good brand .
Have a nice day!
tc
Jun 10, 2008 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Rival Pil-Hc09112 Coffee Makers Logo
19 people viewed this question
Top Rival Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Rival Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
