Question about Proform Walking Belt For The 375 Si Treadmill. Model Number: Pftl31561
Belt slips while in use
Belt slips to the left while in use
  • Proform Master
  • 914 Answers
Try adjusting the tension on the running belt. This video is the rear roller replacement on a Life Fitness 95TI, but includes the belt adjustment. This is a different machine than yours, but it is the same concept.
Posted on Jun 04, 2014
When I turn my steering wheel on my 2001 Camry hard right or left it makes a squeaking sound, why?
The belt is slipping that drives the pump as the pump is pressure locking at the stops and the squeal is the belt slipping on the pump pulley
Apr 18, 2017 | Cars & Trucks
Belt keeps slipping on treadmill
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Belt has moved to the left
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension atreadmill beltwhen it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures forhow to tension a treadmill running belt.
  1. Adjust for no slippage of thetreadmill walking belton the front roller (Often referred to as the "Stomp Test")
  2. This procedure requires twobelt gauges or calipers
Mar 16, 2014 | Precor Exercise & Fitness
New running belt tracks to thr left
Feb 04, 2014 | Precor C962i Treadmill 220V
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Walking belt won't center and drifts to the left...sometimes seems to slip
http://www.youtube.com/watch?v=pStE-LlgIG4&feature=related
Please see this video for adjustment, you can see too another videos in the same web page from youtube.com such adjusting the deck belt,etc.
sincerely.Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 11, 2011 | Exercise & Fitness
The belt slipped
The belt has probably slipped down below the carrier, it's easier to take the shaft out, install the belt then put the shaft back in. Be sure to turn the shaft top to the front with a 1/4 in. wrench to lock it in place.
DickyO
Apr 14, 2010 | Lexmark Wheelwriter 1500 Typewriter
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Adjust tension on fan belt
Your '90 Benz has a belt tensioner that is automatic. You just insert the correct tool to ease the tensioner pulley, (The tool is inserted into the bracket for the tensioner pulley), to the left as you're facing the car. Then slip your serpentine belt off. Reinstallation is a reversal of this process. (I believe it's to the left, don't quote me on that)
The radiator support in front, should have a diagram of how the serpentine belt goes on the pulleys.
If your serpentine belt slips, then the belt tensioner pulley assembly is bad, needs to be replaced, or the serpentine belt itself is worn out.
Apr 19, 2009 | 1990 Mercedes-Benz 300 Diesel
Proform Walking Belt For The 375 Si Treadmill. Model Number: Pftl31561 Logo
73 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
