Question about Vehicle Parts & Accessories
97 toyota corolla no fuel no fire
Replace fuel pump
    Top Expert:
  • 2,044 Answers
There are a few things I would check before changing the Fuel Pump. There is a Camshaft/Crankshaft Sensor that if the sensor went bad, it will not get a Reference Zero and therefore, No Signal to the Pump. I would ensure there is Spark. you can Always Cheat (easiest way) and spray Starting Fluid into the Intake and if it starts, then it is the Fuel Pump.
Posted on Apr 01, 2014
Not starting
you need three things to start a car gas /fire /and timing check the timing first then see if you are getting fire to spark plugs then pull your fuel line at motor crank motor see if gas Is present no gas replace fuel pump no fire replace coil if timing has jump replace timing belt
Nov 18, 2013 | 2005 Toyota Corolla
Engine turns over but will not fire
Don't know why you would expect to smell gas
Could be the fuel pump
Mar 18, 2013 | 2009 Toyota Corolla
Location of fuel pump relay 1994 toyota corolla
The fuel pump relay is located in the fuse box drivers side of fuse box
Jan 26, 2012 | 1994 Toyota Corolla
I can't find the location of fuel filter in my toyota corolla 2002 1.8 lt engine.
The fuel filter for a Toyota Corolla from 2002 and later is inside the fuel tank there is no external fuel filter. It's generally assumed that these filters don't need to be replaced unkless the fuel pump is replaced which is also inside the fuel tank.
Mar 25, 2011 | 2002 Toyota Corolla
What is the firing order for 1995 toyota carolla?
Here is the info. you requested. Firing order 1-3-4-2. distributor rotates counter clockwise
Don't forget to rate this post!!
Sep 29, 2010 | 1995 Toyota Corolla
97 corolla power steering pump 2 vacuum(?) hoses / tubes
they are the bellows breather pipes ,leave well alone they are meant to be their
Apr 25, 2010 | 1997 Toyota Corolla
I have a 1989 toyota corolla that was running fine, then it died and will turn over but will not start, I have replaced fuel pump , distributor cap, The Timing belt is in great shape and is tight.. and...
check to see if u have fuel going to injectors or fire to spark plug if there is no fire coming out of distributor replace pickup coil inside distributor
Apr 04, 2010 | 1989 Toyota Camry
1993 toyota corolla fuel pump fues are relay
to check the fuel pump on you car you need to put ignition in the on position and open the butterfly of the MAF sensor that is mounted on top of your air filter. Toyota's fuel filter won't come on unless there is air going in the engine. your problem may not be the pump, so you need to check the pump properly.
Apr 28, 2009 | 1993 Toyota Corolla
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
