Question about Sharp AQUOS LC-60LE832U 60" Class LED LCD HDTV
TV won't turn on...power icon flashes 1 short, 3 long flashes
Unit won't turn on. All that happens is the power icon on the front flashes 1 short, then 3 long then starts over
    Top Expert:
  • Sharp Master
  • 75,417 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 31, 2014
TV wont start up, blue power icon flashes 3 long and 1 short flash repeatedly
You need to reboot the tv. you've had a signal drop which locks up the tv. call sharp techicon1.png support and they will talk you through a reboot.
Apr 19, 2014 | Sharp Aquos Televison & Video
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ·This will reset the TV in order to fix the problem.
    ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
How to reset LC60LE810UN
How to perform a cold hard rest on the Sharp LC-60LE810UN TV? It won't power on and just blinks.
Apr 14, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic 56" HDTV Projection TV. Model PT-51HX42 TV power button flashes 3 times and then turns off
You have a defective temperature sensor
3 blinks flashes oncenevery 5 seconds
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Jan 24, 2006 | RCA F27450 27" TV
Sharp AQUOS LC-60LE832U 60" Class LED LCD HDTV Logo
131 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
