How do i find my wep key
How do i secure my optimumwifi
    Problem Solver:
  • 6 Answers
1: Instruction manual
2: Find it
3: Do it / or call Comcast and tell its for your grandmom and she forgets where she lives but, she knows she forgets where her wep key is...
Posted on Mar 31, 2014
How do i find my wep key how do i secure my optimumwifi
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Apr 02, 2014 | Computers & Internet
How do i find wep key
Connect your router to computer with lan cable then you can access it with default link http://192.168.1.1 then type user as "admin" and password as "admin" or blank or "password" then you can see settings of router. Click on wireless then wireless security WEP key note down the code it is your password to connect wireless. Let me know if you need further assistance. Thanks for using FixYa.
Apr 06, 2011 | D-Link DIR-615 Wireless Router
What is the wep key
WEP is the security key set up to keep unwanted people off of your network. WEP is easily cracked so it is strongly advised to change over to WPA or WPA2 for much stronger security. When you connect a device to your router over wireless it will ask you for a key. If you have the router set up to use WEP security, you will provide the WEP key.
http://compnetworking.about.com/od/wirelessfaqs/f/wep_keys.htm
Feb 27, 2011 | 2wire (1000-400108-001) Router
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
What is the wep key
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:
  • 1A648C9FE2
  • 99D767BAC38EA23B0C0176D15
WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi routers, adapters and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other. The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
Feb 15, 2011 | Linksys E3000 Wireless Router
Asking 8digit network key
Sounds like your wireless network is setup to require a password (it has encryption) most commenly used is WPA, WEP and WPA2, you will have to ask the person who setup the network for the password.
Here is some more information from the NETGEAR site on WEP encryption for a wireless network:
What is WEP Encryption for Wireless Networks? Wired Equivalent Privacy (WEP) is a security protocol for wireless networks that encrypts transmitted data . It's easy to configure. Without any security your data can be intercepted without difficulty.
However, WEP was an early attempt to secure wireless networks, and better security is now available such as DES, VPN, and WPA. See the Guide to Internet Security to learn about network security.
WEP has three settings: Off (no security), 64-bit (weak security), 128-bit (a bit better security). WEP is not difficult to crack, and using it reduces performance slightly.
If you run a network with only the default security, where WEP is turned off, any of your neighbors can immediately log on to your network and use your Internet connection.
  • For wireless devices to communicate, all of them must use the same WEP setting. (40-bit and 64-bit WEP encryption are the same thing - 40-bit devices can communicate with 64-bit devices.)
While there is no extra performance cost to encrypting the longer key, there is a cost to transmitting the extra data over the network. 128-bit security is not much more difficult than 64-bit to crack, so if you are concerned about performance, consider using 64-bit. If you're very concerned about security, use WPA, which replaces WEP with a protocol that is - given current technology - impossible to crack. There's a good overview in What's New in Security: WPA (Wi-Fi Protected Access).
The WEP concept of passphrase is introduced so that you do not have to enter complicated strings for keys by hand. The passphrase you enter is converted into complicated keys. Choose passphrases with the same care you would important passwords.
  • With 128-bit encryption, you need to enter a passphrase to generate each key.
  • All four keys must be specified, because WEP switches between them to make your traffic more difficult to break.
  • All devices within your LAN must use the same passphrases (i.e., the same keys).
WEP is not necessary if you have a gaming console such as PlayStation or Xbox, and there are no other computers on the network.
Read Instructions on how to Configure Wireless Security (WEP/WPA/Access list). Instructions are also included on the User Manuals and Reference Manuals for wireless products (available on the Product page on this site as downloads).
Doc ID: N100684.asp April 7, 2003
Feb 01, 2011 | Computers & Internet
Where is the wep for it
hi
You can find the WEP or WPA Key settings for your router under the "Wireless" or "Wireless Security" sections in your router settings on your PC. Security must be set to WEP key not to any other type of security setting in order for you to have access to WEP Key information
Jan 09, 2011 | Arris SURFboard® SB5101 Cable Modem
Informed WEP key is a 10 digit number. could 231408&sid nos. & characters be my WEP key?
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
Oct 30, 2010 | Computers & Internet
What is the WEP key
WEP is an older network security method that's still available to support older devices, but it's no longer recommended. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. However, WEP security is relatively easy to crack. f4008eb.jpg
Nov 16, 2009 | NetGear WGR614 Wireless Router
Can't find security key
the wep/security key on 2 wire modems is located below the serial number label on the side of the modem.
Sep 25, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
