Question about Kitchen Appliances - Others
My ford excort fuel pump keeps shutting down ireplaced the pump3 weeks ago it shut down after 2 weeks the cars bien doing this off and on for about 6 months i keep replacing things and its fine for a
Fuel pump problems
2 Suggested Answers
  • 6 Answers
SOURCE: fuel pump keeps shuttind down
Go to a mechanic and/or youtube. Next
Posted on Mar 31, 2014
Fuel pump keeps shuttind down
Mar 31, 2014 | Kitchen Appliances - Others
Ive got a 93 mazda mx-6. the motor came out of a 97 ford probe 2.0. with that being said.. 2 days ago, i drove it down a bumpy road (slow) at a coast. it dies and won't start. ive looked everywher
According to the wiring diagram, there is no inertia switch on a Mazda MX-6. The fuel pump circuit only has a pump relay which is powered by a fuse and grounded by the computer.
And if the car did have an inertia switch it would not affect the ignition system.
If you have no spark and no fuel pressure I would check the circuits for the pump, coil, and computer at those fuse locations and beyond. Could have shaken something loose at the key switch or in the wiring.
Sep 16, 2012 | 1993 Mazda MX-6
1997 buick hard to start why?
Have the fuel; pump checked for pressure bleed down after sitting, it should hold pressure within 5 PSI of rated running pressure after shutting sown the engine for extended periods.
Sep 02, 2012 | 2002 Hyundai Santa Fe
Engine shuts down
The only way to know for sure is to hook a gauge to the rail and check the fuel pressure when it won't start.
Sitting for a few minutes and restarting is normally a sign of a relay or coil cooling off.
There should be a EEC relay that powers the dist module and ECM.
I know you said you have spark, but it could be something else
related.
Also, if you have spark at the right time and no fuel pressure, you should be able to use starting fluid to substitute.
I don't suppose you have dual tanks and the switching valve is the problem ?
Jul 05, 2012 | Ford Cars & Trucks
I have a 1991 ford F150 6 cylinder with dual tanks. I just changed the oil,oil filter,fuel filter,air filter,and master brake cylinder last week and the truck was running good(started every day since)....
Hi :) That is normal. When you first turn on the key the prime relay kicks in for the gas pump then shuts off. Once you start the engine the fuel pump is restarted buildes pressure as the engine needs it. When you shut the key off the pump shuts down.You could check the fuel pump relay which is different then the prime relay or check the spark module on the distributor housing. And the wire that go to all control module have a bad habbit of cracking and turning green with corrosion.
Mar 17, 2011 | Ford F-150 Cars & Trucks
My ford 1996 explore keeps shutting down on me, what am i suppose to do.
A "shutdown" will generate a light. When engine lite is on, take it to Autozone and have them run an ODB test.
They will specify the cause of the light.... and therefore, the cause of the shut down.
Possibles are:
1. clogged fuel filter
2. failing fuel pump
3. Dirt in intake system
4. clogged exhaust (cat. converter)
Nov 23, 2009 | 1996 Ford Explorer
I will be driving down the road and the car shuts down.The doors unlock and 2 secs later the car just shuts off. About 3 weeks ago They replaced my fuel pump. It did it once right after I got the car back,...
that valve that you seen is to your fuel rail and may have to be bleed. So it sounds like when you had a fuel pump problem during that time you were getting air in your fuel system. After replacing the fuel pump they did not properly bleed your fuel system to the correct pounds of pressure.
Oct 07, 2009 | 2001 Chevrolet Malibu
2001 ford explorer sport engine stopped while I was driving
I would check under the hood for the fuel pump relay and have that tested and if that is good it maybe the fuel pump
Jan 24, 2009 | 2001 Ford Explorer Sport
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
