Question about Kenmore HE2 Plus Front Load Washer
All of the water filling my kenmore washer is flooding out bottom
I have a kenmore 110 washer and all of the water that goes into the tub is flowing out of the front bottom of the washer. Is this the water pump, or could it be something different?
  • 15,935 Answers
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
When hot water goes in tub waster makes norris kenmore waster top lead model 110 serial # c 80207234
Try adjusting the water tap for the hot water. Open or close a little while it is filling up.
Jan 23, 2011 | Kenmore 23822 Top Load Washer
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore 110 washer
if screens on both ends of cold fill hose are clean replaced valve have seen restricted flow even with good flow to valve but be sure screen in valve is pulled and cleaned be sure to reinstall it
Aug 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
212 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
