Question about Sharp R-360E Microwave Oven
Needs a lcd panel as lights half way
Will purchase lcd unit
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
GE, Model# PVM2070SM1SS microwave - touch panel does not respond
GE has a special program, and your microwave is very likely a part of this program. Please contact GE consumer relations asap at 800-386-1215, at the prompt press 5. Our same microwave model has that problem. GE is replacing the entire microwave free of charge.
Jun 21, 2012 | GE PVM2070SMSS Microwave Oven
My micro oven NN-C2000P No lcd light display even the 240 v suppy is going in the Power supply panel. the door is totally close.
IS GREEN LIGHT IS ON BEHIND LCD ? ANY LCD NEEDS BACKLIGHT TO DISPLAY. JUST LOOK OUT FOR FUSED BACKLIGHT. LET THE DOOR OPEN OR CLOSE THE DISPLAY SHOULD BE ON.
Apr 01, 2010 | Panasonic NN-T551 Microwave Oven
Electricity works but microwave won't only half a zero shows on on panel
Than half of a C more than likely stands for Capacitor. If the large Capacitor has faile the magnetron will not produce RF and your Microwave will not heat but the light and fan may still work. (There are variations on intenral circuits) There are usually 3 things that cause a no heat symptom then there are visible signs of power on your unit.
1. The capacitor
2. Chassis Diode
3. Magnetron
and in very rare cases
4. The control panel
5. Door interlock Micro-switch
From what you described on an 1100 Watt unit I would get it repaired. If they tell you the Magnetron is bad you might want to re-think repair as it will be at least 50% of the total unit replacement cost.
Jan 11, 2010 | Magic Chef MCD1311ST Microwave Oven
BUTTONS ON CONTROL PANEL DOESN'T WORK REGULARLU
HI, unfortunately, the actual part you need(Control board), has been discontinued. it is best to just purchase a newer unit in this case. This unit is not repairable at this time due to the unavailability of the components.
Aug 06, 2009 | Whirlpool RMC275PD Microwave Oven
Whirlpool GH7155XHS microwave shows partial display
The display is defective and requires replacement. Unfortunately, the display is probably incorporated as a unit with the control panel and must be purchased as an entire service part. This will cost $80-$120 depending on the oven make & model. It will cost more if you have a repairer install the part.
It may be more cost effective to replace the oven. Microwave ovens are rather inexpensive these days.
Mar 06, 2009 | Whirlpool GH7155XHS Microwave Oven
Sharp R1210 LCD display
Actually there are two good options for you.
First, we repair these for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
Or you can order a modified control unit from us which has our proprietary fixes designed to repair and prevent these common display failures.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 08, 2008 | Sharp R-1210 Microwave Oven
Sharp R953M combination microwave oven
No this lcd card is only a diffuser to even the light out over the display . The part you require is SH3816 Pcb display available from CIS £68.43.
Jun 16, 2008 | Microwave Ovens
Surface Light & Vent Fan Won't Work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 17, 2008 | GE JVM1440 Microwave Oven
Sharp R-360E Microwave Oven Logo
66 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
