Question about Miele Vacuums
Miele 22120 loud noise in motor
My vac is making a loud noise in motor
reddevil6
  • 1673 Answers
SOURCE: Bissell 3510 Vac with loud noise but not belt
Did you check the brush roll, may have a problem with it. But you could have a problem with a motor bearing going bad, they getting loud, also if there is a problem with the motor fan, that may be the cause of it being loud. Bissell 3510 either is obsolete or is thw rong number, it doesn't come up at the Bissell site.
Posted on Mar 18, 2008
  • 430 Answers
SOURCE: motor makes loud growling noise, no suction on
Growling sound on a canister is normally caused by a suction fan wobbling loose due to damage or a bad bearing. Loss of suction would occur if the fan is loose or damaged. If the bearing is bad but the fan intact you will still lose suction as the motor will not run properly out of balance. Take it to a Miele service center for parts
Posted on Sep 07, 2009
  • 69 Answers
SOURCE: The vac is making a loud noise and brush is not
Drive broken
Posted on Mar 27, 2010
  • 20 Answers
SOURCE: dyson vac animal upright
brush roller cracked or out of round. needs replacement.
Posted on May 06, 2010
  • 250 Answers
SOURCE: making an unusual noise
could have ruined the belt or the bearings try checking both
Posted on Jun 16, 2010
My miele flamenco II vacuum cleaner motor makes a loud grinding noise what's wrong with the motor?
Hello Louis Casado,
Most of these motors make noise because the bearings have gone bad and need replacing...
(loss of lubricant or other-than-round ball bearings).
Alternatively... the rotor brushes have picked up something that is clashing with the housing... and needs to be resolved.
Clean it all... really good & run it without a load...
If all else fails to remedy your situation... pull the beater brush and cut everything but the fixed bristle rotor brush... clean it... cut it free... check out all clearances... and return it to service
Hope this helps!
Happy hunting!
Oct 18, 2016 | Miele Vacuums
Hoover steam vac spin vac making loud noise sparks flying
The only source for electrical sparks is the motor so it must be checked. Bad motor brushes or a broken wire are possible causes. Do not use in this condition.
Aug 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
Why is my central vac. making such a loud noise. It sounds like jet getting ready for take off. It seems to be getting louder. I'm not using it because i'm afraid it's going to explode or...
The bearing or the motor is warn out they last 15 years in the case. In some rare case the brush ware out or the rely can catch fire, most central vacuum are not made to be oiled! Hot oil will catch on fire. Best to unplug the vacuum unit call a few shops and ask replacement motor cost, if you remove the Vac and take to them it will cost less.
Jun 25, 2011 | Vacuums
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Apr 13, 2009 | Vacuums
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Vacuums Logo
23 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
