Question about Emerson LC320EM2 32" LCD HD Television
Tv lighting problems
Lines up and down in tv screen and picture fades in and out slow where you cant see it but you barely can see the picture but good sound
  • Emerson Master
  • 3,320 Answers
How old is the TV?
What is it connected to?
Sound comes from a different source and is not an indicator of issues with the TV.
Posted on Mar 31, 2014
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
My 42LH2000 tv has a problem with picture
possible lcd failure or time-control board failure maybe with a photo I might be able to answer more accurate for your problem !!!
Jul 04, 2014 | LG 42LH2000 42 in. HD-Ready LCD TV
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Sanyo dp42849 picture is slow
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
Picture just went black. menu, inputs - nothing
Is the standby light blinking? If so how many times? It could help narrow down where the problem is. At this point it could be anywhere. Most likely in the high voltage section. Get me more info and I will try to help.
hardrocko
Jan 24, 2010 | Hitachi 61SDX01B 61" Rear Projection...
My tv screen starts normal then fades gradually The tv is working, but all I get is a black image
Check the CRT ground wiring. I saw this on a computer monitor after I forgot to reconnect the wire from the ground line around the picture tube. It would start normally and fade out over a period of five-fifteen seconds.
Caution: pull the plug and wait several minutes, then check for voltage between the bare wires around the outside of the picture tube and chassis ground before you put you touch anything. If you get voltage, this is definitely the problem, and I've just saved you from a nasty shock (could be almost as high as 2nd anode voltage). If you don't get voltage, inspect at will.
Jul 11, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Jul 17, 2007 | JVC AV-27230 27" TV
Emerson LC320EM2 32" LCD HD Television Logo
51 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
