Question about JP97-A1450-1 Winch Front Bumper Stinger Jeep Wrangler TJ 199
I used a Jeep Wrangler (stick shift) in 4-low to tow a car. Now I can get it into 4-hi or 4 low, but I cannot get it into 2 WD. Any suggestions? Thanks
My 1997 Jeep Wrangler manual transmission will not go back in 2W mode. I can shift between 4-Hi and 4-low, but not into 2 wheel drive.
  • 957 Answers
Did u try putting it in N AND THEN SET THE SWITCH TO 2 WHEEL
Posted on Mar 31, 2014
1997 jeep wrangler stays in gear
97 wrangler
what does that mean, it has no clear meaning at all.
first is car a auto or stick (mines a stick)
stays in gear can mean many things,,,
1: A/t shift lever stuck in drive, you never said what gear,?
2: M/t sticks shift car, , the car moves in gear, with clutch held to floor.
i cant shift to neutral?
I cant shift to park.
I cant what? be clear. please
Jul 01, 2016 | Jeep Cars & Trucks
91 jeep wrangler YJ shifting problems
do you mean it wont go into gear ? if so what gears ? it could be the clutch going out , if the pedal is soft or easy to push down than it probably needs a clutch. next time it wont go into gear try pumping the clutch or putting it from 2nd to 1st or what ever gear it has problems with
Dec 18, 2013 | Cars & Trucks
4x4 indicator light
I have seen this issue in some 4x4 vehicles. The issue may be that although you have moved the shift lever, because there is pressure on the axle components, the vehicle has not released the front wheels. After shifting from 4x4 to 2x4, allow the vehicle to move without torque for a few seconds, allowing the components to move into 2x4.
Jan 14, 2012 | 1991 Jeep Wrangler
I have a 1987 jeep wrangler and it will not shift into 4 wheel dr
The front axle connects 4wd by vacuum. check the vacuum hoses that run to the actuator. Pay close attention to the vacuum hoses running underneath the battery as battery acid can eat thru those hose easily. Good Luck.
Dec 27, 2009 | 1987 Jeep Wrangler
4 wheel drive is messed up
Have you tried letting up on the thhrottle at the same time you shift? That takes the load off the gears and allows the shift to freely occur. Good Luck, Ned
Sep 16, 2009 | 1995 Jeep Grand Cherokee
4 wheel drive doesnt work.
Has this Jeep been modified at all?
It sounds like the shifter cable was reinstalled backwards.
Specifically the 4-Low "Not Climbing Well". 4-Low should give you the best torque and hill climbing ability.
Do you feel any "Binding" in the steering wheel (difficult to turn)?
Remember a Jeep uses real driveshafts and differentials to give you 4WD - you cannot engage 4WD or 4-Low on dry hard surfaces. It needs a little bit of slip between the wheels for turns.
Check you're fluids too.
Jul 11, 2009 | 1992 Jeep Wrangler
Jeep stuck in 4 wd and transfer case shifter moves about freely
OK, simple problem, and a quick fix...  (And I consider changing my own oil to be the extent of my automotive education.)  I had this happen today.  A little online research from the jeep community showed me the external cable that connects your 4WD knob with the arm on the transfer case is held on that arm with a plastic clip that is fond of disappearing.
When the jeep cooled down, I crawled under, found the cable end hanging freely, and simply set it back on the arm.  With no clip it will pop off again, but it allowed me to shift back to 2WD and roll home.  I understand a zip tie will keep it in place until you get a 3/16 nut of some sort.  (Can't be more specific about the nut yet, I'm waiting for more info.)
It was a relief to find out that I didn't need to have anything done with the transfer case, etc...  If you show the dealer the problem, I'm told they often want to replace the whole cable, as the clip comes as part of the whole.  Waste of time and $$$, and I canceled the appointment with the dealership when I learned the simplicity of the problem.
Jun 02, 2009 | 2008 Jeep Wrangler
SOUNDS LIKE THE SHIFT LINKAGE HAS BECOME LOOSE. THE GOOD NEWS IS, THE WARRANTY IS STILL IN EFFECT. PERHAPS A DEFECTIVE PART IS THE CAUSE? IT IS TOUGH TO SAY THE EXACT REASON WHY THIS HAPPENED WITHOUT LOOKING AT IT FIRST HAND. SORRY FOR YOUR INCONVENIENCE. HOPE THEY SOLVE THIS MYSTERY SOON SO YOU CAN GET BACK ON THE ROAD, AND OFF ROAD TOO.
May 26, 2009 | 2008 Jeep Wrangler
Don't know how to use 4WD on 1995 jeep cherokee
the jeep cherokee has 2 different types of 4 wd systems. the command trac has 2 wd, 4hi, neutral and 4 low. if driving on pavement make sure it's in 2 wd. it also has shift on the fly, up to 60 mph you can move the lever to 4 hi and it will not hurt anything. if trying to go to 4 low, be rolling less than 5mph and put the trans shifter in neutral and move the 4wd selector to 4 low. do the reverse to move back to 4 hi or 2 wd
Dec 21, 2008 | 1995 Jeep Cherokee
JP97-A1450-1 Winch Front Bumper Stinger Jeep Wrangler TJ 199 Logo
104 people viewed this question
Top Fab Fours Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Fab Fours Vehicle Part and Accessory Expert? Answer questions, earn points and help others
