Question about Briggs & Stratton Garden
Bad pressure bad or no pressurs
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Faulty/stuck valve ,faulty pump or air in pump
Posted on May 15, 2014
My daughter has 99 Buick lesabre how do you know if the oil pump is bad
Oil pressure test , remove the oil pressure sender an screw in a mechanical pressure gauge an test the actual pressure . Is the engine making any noise ? knocking , rattling etc... Oil light on ?
How To Check Oil Pressure EricTheCarGuy
Jul 11, 2016 | 1999 Buick LeSabre
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
I have a 2003 Ford Expedition with a 5.4 engine, when I go to crank it, it turns over quite a few times before it finally starts, any ideas?
Check fuel system pressure if the pump has a bad check ball or the fuel pressure regulator is bad, pressure is hard to pressurize in the lines. Test dead head pressure then operating pressure the a fuel pressure leakdown test. That way you know what actually needs replaced so you don't guess. When you first pressurize the fuel system it should have 30 to 40 psi if it falls fast before you initialize starting the vehicle the check ball in the fuel pump is bad so the whole assembly and fuel filter will need replaced. If you start the vehicle and pressure does not regulate at 30 or 40 and you accelerate and the pressure does not max out it is a fuel pressure regulator. It might be in the fuel rail or in the fuel pump assembly in the tank.
Feb 20, 2016 | Ford Cars & Trucks
Why does my rear air suspension system come on nothing leaking but my 2002 Oldsmobile bravada will not go up
Bad pump or a leak. Pull the lines fro the rear air shocks, Fell for pressure build up in the line. Find the pump, and check pressure there also. No pressure at the pump, it's bad. Pressure at the pump, but not at the shocks, bad line. Pressure at the shock line, bad shocks.
Jul 10, 2015 | Oldsmobile Cars & Trucks
Computer show the engine oil pressure not enough need to stop engine how to improve
Generally low oil pressure is due to a failing oil pump. If you have a mechanical gauge you can pull the electric oil pressure sensor and use that gauge there to verify if the pump is bad. If pressure is low on the mechanical pump then the pump is bad. If the mechanical pump reads good pressure then its the pressure sensor that is bad.
Apr 02, 2015 | Cars & Trucks
Has no oil pressure i drove it over ten mile still runs good but no oil pressure
Just because it runs good is no reason to drive it into the ground. No oil pressure can ruin an engine fast. Hopefuly the reason no oil pressure is the sensor is bad, it's connection is corroded and thus bad. If mine I would take it to a shop and have them actually measure the oil pressure with a mechanical gauge. If no oil pressure that way, you know you have a serious problem. If the mechanical measurement is good, then you know that The sensor is bad, it's connection is bad, or the oil pressure light or ? gauge
is bed on the dash panel. Good luck.
Mar 15, 2015 | 2007 Chevrolet Tahoe
What will be the problem if the common rail is having low pressure?
Hi
common rail pressure low problem could be:
1 bad hi pressure pump
2 bad rail pressure monitor sensor
3 bad pressure regulator sensor
4 bad injector/s back leak
Aug 15, 2014 | Cars & Trucks
Oil pressure
Oil pressure problems:
Bad oil pressure sensor.Bad wiring May touch grounded parts leading to red low pressure signals.Bad (thin) oil.Cloged filter.Bad/worn oil pump.Worn cranckshaft bushing.Rare:loosed/worn valve shaft.
Cheers, hope u deal it well,share.
Oct 27, 2013 | 2006 Volkswagen Passat
No pressure
The pump has burnt up...thbey are cheap units and go bad.
its not a ? of will the pump go bad, just when...they all go bad
Jul 22, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Why is the pump cutting in so much
Check your water pressure tank air pressure, turn off pump, drain off all water pressure and using a air pressure gauge check pressure at the schrader valve on the water pressure tank. It should be 2 lbs below pump cut-in pressure, they come factory charged at 30 PSI...works for most residential systems. Most likely you have a bad bladder in pressure tank.
Other possibles are a broken line between pump and pressure switch/pressure tank or bad pressure switch.If you have a pressure gauge on the water system(should have one near pressure switch) see if it is cycling at the right points if it is the switch is good. If pressure is dropping with NO water uasge in house you have a leak.
Most likely a bad pressure tank bladder is the problem.
Oct 24, 2009 | Jet Plumbing
Garden Logo
44 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
