Question about Kitchen Appliances - Others
Grater ony grates if button pressed continuously
When I try to grate food machine only works if button continuously
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
SOURCE: I need a detachable stem
Hi... if you have a La Machine I, the item you want is available on nelsonappliance.com for $6.99 + s&h. Search for "disk adapter". I'm not sure about the La Machine II, but the phrase "disk adapter" will probably help you search. Good luck!
Posted on Nov 08, 2008
  • 10865 Answers
SOURCE: Slicing Grating Blade for a Farberware 286 food processor
go to this site and you can order what you need:
http://www.smallappliance.com/department.asp?cur=USD&sid=18956&gid=18970&shopBy=Category&cam=drg_247-10377&drg=247-10377&gclid=CPPEqdb6zZgCFQw9GgodtGMO1A
Posted on Feb 08, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Posted on Mar 17, 2009
heatman101
  • 43501 Answers
SOURCE: hotpoint fza21 fast freeze not working
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
Tip
A clean grater/zester with no trouble
Do you have the feeling that grating and zeisting your food is not worth the hastle of cleaning the tool afterwards?
Well, here are a few simple tricks that help you easily clean your grater and zester, remove all residues and keep you from grating your fingers attempting to clean it.
The first tip is to use oil. You can use a bit of olive or seeds oil and add it on the grater's surface. This way you will have a well-oiled surface that will not prevent the grating action but will help removing leftovers from the grater.
After the grating is done, a useful thing to do is brushing both its sides with a freshly cut lemon and then rinse. Most of the leftovers will come off like that.
Then take a toothbrush reserved for the kitchen and with hot water and soap brush the whole surface of the grater so to thoroughly clean it and then rinse it and let it dry completely before you put it away, to avoid rusting.
Another quick way to dry these kinds of items is to put them in the warm oven for 10 minutes.
Enjoy your clean graters and zesters!
on Nov 10, 2013 | Home
How do I grate horshradish
Do you have a root or prepared in a jar...? If in a jar its already grated....if in root form any kitchen grater will work. They sell a 4 sided grater with different grating options for about $8 if needed.
Jan 29, 2015 | Grilling
What is a grater?
"A grater (also known as a shredder) is a kitchen utensil used to grate foods into fine pieces. It was invented by Francois Boullier in the 1540s." (Wikipedia)
Oct 08, 2013 | Home
Do you need a special grater to grate chocolate?
You don't need a special grater for chocolate but it's worth investing in a good grater that is sharp and has a couple of size options. Kitchen Aid do a good range of graters.
Feb 25, 2013 | Cooking
Do you have a grater blade for a Farberware 286 processor. It is used for grating cheese and vegetables.
Hi gee helen...
Go to the following website they carry parts for Farberware food processors.
They also have a toll free number to contact them: 1-800-675-9491
Please take time to rate me
http://www.bettervac.com/menu_farberware.asp
Sep 01, 2011 | Vacuums
How do you take the grater off the juiceman2 the part that the fruits and vegetables get grated. Thank you
how do you take the grater off the juiceman2 the part that the fruits and vegetables get grated.
Dec 12, 2009 | Salton JM411 Juiceman II Elite Juicer
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
