Question about Garden
No pressur wont give pressur at times but it runs grat
    Top Expert:
  • Garden Master
  • 12,957 Answers
If you are getting pressure at times that would seem to indicate that the pump is till ok. There is a pressure bypass valve that operates when you let go of the trigger - it does not let internal pressures build up monumentally when you release the trigger........if this valve gets stuck in the open position the pressure is reduced considerably because of the bypass path. Unclog it, clear it. or replace the valve to restore normal operation.
Posted on Mar 31, 2014
Howdoes increasing the density of a gas affect pressure
You are obviously talking about gasses within containment. Essentially if you are increasing gas density means compressing it within a vessel. More molecules of it are being introduced within a vessel. which will increase pressure upto the point that the pressure becomes too grat and the containment vessel fails.
For examples of this look at steam engines
May 27, 2015 | Cars & Trucks
Sputtering on 1991 nissan maxima from a stop then at 2000 rpm or so it will run grat
its your idyll. You need to turn up the gas flow to the fuel injection or the carburetor.
Aug 26, 2012 | 1991 Nissan Maxima
1989 buick century 3.3 car starts idles but wont run when giving gas it acts like running out of fuel but fuel pump stay running and has pressure new fuel filter spray carb cleaner it will stay running...
have you put a fuel pressure gauge on it if so how many ponds of pressure does it have also if this is a distributerless car turn engine with a socket see if there is slack in rotation if you turn counter clockwise 1/4 turn stop and turn clockwise if so you more than likely have a stretched timing chain or jumped time
Apr 01, 2012 | 1989 Buick Century
My 1990 chevy lumina will start up for few seconds then die. it wont stay running for more than 5 seconds but will starts up every time. when i give it gas it dies immediately
Sounds like low fuel pressure. Check your fuel pressure. If you have the 3.1 liter engine and just turn the key to the "on" position you should have around 41 - 47 PSI. When running it should have about 31 - 44 PSI. If you have the 2.5 liter engine you should have 26 - 32 PSI of pressure when running. I hope this helps and good luck.
Jul 09, 2011 | 1990 Chevrolet Lumina
2000 jeep wrangler turns over several times befors starting. runs grat on the road,never stalls out once you turn the engine off and go to start back up,it starts imediatley,if it sets long time then it...
The in tank fuel pumps on these vehicles have check valves to hold fuel pressure. possible bad fuel pump check valve, Try turning the key to the on position three or four times to let fuel pressure build up and then see if it starts easier
Mar 14, 2010 | 2000 Jeep Wrangler
2001 f350 diesel craks but wont start
SOUND LIKE THE ELECTRIC LOW PRESSURE FUEL PUMP CHECK FUSE TO SEE IF PUMP GETTING POWER. IF NOT REPLACE FUSE AND CHECK THE WIRE TO PUMP.IF PUMP IS GETTING POWER..REPLACE FUEL FILTER FIRST.IF IT DONT HELP.COULD BE THE ELECTRIC LOW PRESSURE PUMP. FAULTY. IT PUMPS DIESEL FUEL IT INTO INJECTION PUMP TO BE PRESSURIZED TIMED AND INJECT.SEE IF LOW PRESSURE PUMP DONT WORK THE WHOLE ENGINE WONT RUN.THE INJECTION PUMP NEED FUEL FROM LOW PRESSURE ELECTRIC PUMP TO RUN ENGINE.
Aug 11, 2009 | 2001 Ford F350 Super Duty SuperCab
Runs fine gc160 wont give me any pressure. i took the pump apart and cleaned it then put it all back together the pressure was intermediate but now nothing at all
if you give us a bit more information we may be able to assist!
is it a pressure washer you are trying to get running.
the number you give is the model number of the honda engine. 5.5 hp honda domestic use.
what does the pump look like. etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
