Question about Amana ACS3350AS Gas Kitchen Range
Kitchenaid kgsk901sss02 disply don't work oven don't turn on but burner work fine
Burner work but oven won't turn on
    Top Expert:
  • Amana Master
  • 9,472 Answers
You need to replace the control board. Here is that part to order.
Whirlpool 9762793 Cntrl Elec AppliancePartsPros com
Posted on May 01, 2014
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
My kitchenaid range touch pad won't work- no errors displayed, can't turn oven on
careful here. The board needs to be replaced and can cost as much as $300 to $500. Half the cost of a new range. They also have been known to turn on the cleaning mode when baking. Then the oven door locks and cannot get in. Then what ever you have in the oven really gets black and starts a fire. This happened to me a while back. Had to shut off the range breaker and wait til the oven cooled of to open door. Really smelled. Had to buy a new oven because we could not get the burned smell out. I would suggest not to use the oven til new board is installed. Or buy new oven. We bought a AQUALIFT clean oven. It cleans at 250 degrees. Not the high temp of 500 degrees plus.
Dec 31, 2014 | KitchenAid Kitchen Ranges
Touch button won't work
If all buttons don't work then check that connection isn't broke through the I/O board.
If not then board is faulty.
Is you display is lightining or not.
if not then the connction is bad
thanks
please rate my work
Sep 10, 2011 | KitchenAid KHMS155L Microwave Oven
I want to remove the top part of the stove. do i need to remove the seal burners first?
if it is a glass top , Know you don't it will com apart by removing two screws in the front near the top , one on each side , are you going to replace a burner ? also turn off power before lifting top up , it will pivet on the rear
Jul 25, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
80 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
