Question about KitchenAid KGST307 Gas Kitchen Range
DISPLAY BOARD DON'T LIGHT
OVEN DON'T TURN ON BUT THE BURNER WORK FINE
2 Suggested Answers
vvusmc3_9
  • 17 Answers
SOURCE: my kitchenaid range touch pad won't work- no errors displayed, can't turn oven on
careful here. The board needs to be replaced and can cost as much as $300 to $500. Half the cost of a new range. They also have been known to turn on the cleaning mode when baking. Then the oven door locks and cannot get in. Then what ever you have in the oven really gets black and starts a fire. This happened to me a while back. Had to shut off the range breaker and wait til the oven cooled of to open door. Really smelled. Had to buy a new oven because we could not get the burned smell out. I would suggest not to use the oven til new board is installed. Or buy new oven. We bought a AQUALIFT clean oven. It cleans at 250 degrees. Not the high temp of 500 degrees plus.
Posted on Dec 31, 2014
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The touch pad on my Jenn Air Model JES9800BAF does not work. The clock does not display either. All four burners operate normally.
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
Nov 13, 2009 | Jenn-Air JES9800BA Electric Range
GE Model #J TP30B0M1BB Oven The oven stopped heating up on either bake or broil. Light and display are still working
Check to see if 2 of your range burners have failed too.  It would indicate that your breaker needs to be turned off and then back on to get 240 V again.  The panel and 2 burners will work on 120 V just fine.
Nov 10, 2009 | Ovens
Frigidare range glgf376dsm display not working
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Apr 23, 2008 | Kitchen Ranges
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
its not a loose wire. jenn-air is famous for having to replace the display board. once you replace it it will be fine
Nov 28, 2007 | Jenn-Air SVE47100 Slide-In Electric...
KitchenAid KGST307 Gas Kitchen Range Logo
41 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
