Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Freezer works great; frig only at 57-59 degrees. I melted the ice totalling blocking the air duct. I checked the fan, it works outside with 120 applied. There is 120 going to the power at the quick disconnect calling for the fan to run. I can't tell for sure if the fan is turning, fully assembled; or not. I guess it could be restricted?? I can't imagine what else could be wrong. When I melted the ice in the duct, I did a very thorough job. I set the freezer to warmest and frig to coldest. Can you help?
  • 8 more comments
  • bberger632 Jun 15, 2009
    Hi I have done this three times. The second time I left it unplugged for two weeks with the doors open. I checked the fan out of the freezer, it runs fine. There is 120 on the quick disconnect plug at the back of the freezer; calling for the fan to run. This is the top freezer bottom frig model. Please correct the model type on the request. After the two week defrost I ran it for a week, it never got the frig below 55 and the duct totally blocked with ice again. The freezer works great. I set the freezer to warmest and the frig to coldest.
    yes the door seal is very good
    The door seal I believe is ok. I can pull the dollar bill out without a lot of resistance, but the seal is good enough to resist opening the door for the first 1/4 inch of pull. It feels like suction for the first 1/4 inch of travel towards open, then it lets go.
    This is a top freezer model. Freezer works great; frig cools to only at 57-59 degrees. I melted the ice totalling blocking the air duct. I checked the fan, it works outside with 120 applied. There is 120 going to the power at the quick disconnect calling for the fan to run. I can't tell for sure if the fan is turning, fully assembled; or not. I guess it could be restricted?? I can't imagine what else could be wrong. When I melted the ice in the duct, I did a very thorough job. For the test run, I set the freezer to warmest and frig to coldest. I checked the door seal. I left it to defrost for 2 weeks. After 2 days of not getting below 55 the duct was fully frozen up again. Can you help?
    Model # GLRT186TA 18.3 Cu
    How do you check to see if defrost timer is advancing/switching.
    How -- Check defrost heater.
    How -- Check defrost thermostat. (Limiter)
    There is no ice build-up on the coils, I am pretty sure. I can check again, I don't remember how long (in mins) it took me to get to the disassembling of the freezer compartment in my repair effort. Also the freezer freezes quickly and very solid. The frig temp is the lowest since the prob started -- 49.5, it's been running 3 days with freezer 1/2 full ice cubes and frig 10% full juice cartons. and fruit.
    Hi that is great info -- but can you see if I need to do each of these. some are a bit difficult. The reason I ask is when I open it back up I am sure I will find this condition. The duct will be frozen shut; the coils will be free of ice; If so what allows the duct to freeze if the coils are free of ice.??
    Hi ---- where is the defrost timer switch? I found the defrost timer. Also I was wrong on my last guess. When I open it up this time there was no ice on coils and the two ducts were completely clear. I opened it up quickly to avoid melting before I could check for ice. ???'s what could be wrong? Still 52 min temp -- freezer works great.
    The defrost timer does not test ok! All terminals are open to all others. Why does this cause a problem?? the freezer and the duct aren't iced up! I fear if I replace this timer it still won't be fixed. Can you explain how it prevents the frig from not cooling if there is no ice - anywhere?
  • bberger632 Jun 16, 2009
    THAT'S A VERY GOOD EXPLANATION! But (always a but) I checked the 120 volts on the plug to the fan and 120 is there telling the fan to run. If you have time I'm interested in your comment. Thank you and I will send payment for your help now. Bob Berger
    Very Helpful, got to the problem quickly. And explained why.
  • 15,935 Answers
Check to see if defrost timer is advancing/switching.
One (or more) of these has failed.
When the defrost timer, heater, or thermostat fail - it will allow for the build-up of ice on the coils.
Without an exact model #, this is as far as we can go for remote troubleshooting.
If you wish - please use the "Continue With This Expert" option so we are connected in the future, and reply with the make/model # for more exact help.
Thanks for using FixYa!!
Posted on Jun 15, 2009
  • 4 more comments
  • blueextc3221
    blueextc3221 Jun 15, 2009
    TESTING THERMOSTAT:
    Some defrost systems use a thermostat (a bi-metal switch) to prevent the defrost heater from overheating. The switch is normally closed. During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a circuit again and the defrost heater starts heating again (as long as the defrost timer is in the defrost cycle). A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire.
    window.google_render_ad();
    The defrost thermostat is located near the defrost heater and is wired in series. It is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
    The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky -never force it. If you decide to remove it, you do so at your own risk - it is prone to breaking. Try warming it first with a warm, wet towel.
    The thermostat is connected by two wires. The wires are connected with slip on connectors or a wiring harness. Firmly pull the connectors or harness off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
    Test the thermostat for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of zero when the thermostat is cold and a reading of infinity when it is warm (40 to 90 degrees F depending on the model). If the thermostat does not pass this test it should be replaced.
  • blueextc3221
    TESTING DEFROST TIMER:
    Directions for testing a refrigerator defrost timer.
    Before you begin to test your defrost timer, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
    Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
    1. Locate your defrost timer. It can be located behind the refrigerator's lower kickplate, in the refrigerator's control panel, or even behind the refrigerator on its back wall. Defrost timers almost always have four metallic terminals extending from the bottom. Once you have found your refrigerator's defrost timer, remove it for testing.
    2. A defrost timer is usually secured inside a refrigerator with at least one screw, but sometimes more. Remove all the screws you find and pull the timer carefully out of the refrigerator. Pull it out far enough so that you can disconnect its wires. Pull firmly on the wire's connectors to remove them. You may need to rock them back and forth a little to ease the motion. Don't worry about which way the connector comes out because there is only one way it can go back in.
    3. Use your multitester to test the timer for continuity. Set your multitester to the R X 1 scale. Place one of the tester's leads on the coommon terminal. It should be labeled "3" or "C". If none of the terminals are labeled, you can locate the common terminal by determining which terminal coincides with the white wire in the connector plug. With one multitester lead (probe) touching the common terminal, touch the other lead to the other three remaining terminals, one at a time. Testing the first pair should produce a reading of zero, or near zero, denoting continuity. The second pair may also result in a reading of zero or near zero. Testing the third pair of terminals should produce a reading of infinity.
    4. Find your refrigerator's timer switch and turn it in a clockwise motion until it clicks. Use your multitester and test the terminals again in the same manner as in the preceding paragraph. In this test, one of the pairs of terminals should produce a reading of continuity. At least one pair, but maybe two, should produce a reading of infinity. One important note to keep in mind is that a pair of terminals that demonstrated continuity in the first test should now demonstrate infinity. Likewise, a pair of terminals that demonstrated infinity in the first test should now demonstrate continuity.
    5. If the test you conduct with your defrost timer does not produce these results, then you should replace the mechaninsm.
  • blueextc3221
    TESTING DEFROST HEATER:
    Directions for testing a refrigerator defrost heater.
    Before you begin to test your defrost heater, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
    1. Locate your defrost heater. It can be located behind the back panel of the freezer section of your refrigerator, or under the floor of your refrigerator's freezer section. Defrost heaters are commonly located beneath a refrigerator's evaporator coils. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
    2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
    3. Defrost heaters are available in one of three primary types: exposed metal rod, metal rod covered with aluminum tape, or a wire coil inside a glass tube. Each of these three types is tested in exactly the same way.
    4. Before you can test your defrost heater, you have to remove it from your refrigerator. A defrost heater is connected by two wires, and the wires are connected with slip-on connectors. Firmly grasp these connectors and pull them off the terminals. You may need a pair of needle-nosed pliers to help you. Do not pull on the wires themselves.
    5. Use your multitester to test the heater for continuity. Set your multitester to the R X 1 scale. Place the tester's leads on one terminal each. This should produce a reading anywhere in between zero and infinity. If your multitester produces a reading of zero, or a reading of infinity, then your defrost heater should most definitely be replaced. There are many different kinds of elements, and so it is difficult to say what exactly the reading should be for your defrost heater. But it definitely should not be zero or infinity. If it is, replace the mechanism.
  • blueextc3221
    CLICK HERE for the Defrost Timer in your unit (most likely in your case)
    CLICK HERE for the Thermostat in your unit
    CLICK HERE for the defrost heater in your unit.
    Your symptoms lead me to believe the Defrost timer is the failed culprit in this case.
    You can find it in THIS DIAGRAM as #23
    Any other questions - let me know.
  • blueextc3221
    The defrost timer is what tells the compressor to turn off... and when to turn on the evap. fan.
    If your timer is bad - the compressor runs non-stop - very inefficiently... and the fan will never come on to circulate the cold air from the freezer.The freezer is cold - but without the fant to move the air around - the fridge will never get cool.
    Any other ?'s dont hesitate to ask - thats why we're here.
  • blueextc3221
    blueextc3221 Jun 16, 2009
    CLICK HERE for an electrical schematic of your unit.
    Please see that the cold controller for the fridge is BEFORE the timer - so any input gained from it is now controlled by the timer.
    The timer's output controls the heater, and the defrost thermostat, and both the evap. and condenser fans.
    If you are testing the freezer fan with the door open, and not jumpered - the fan will continually be send voltage because it senses the door open. Once you close the door - chances are it turns off.
    Sadly the more elaborate diagram I have access to is illegible... and it would tell me the location of the switch in the circuit.
    HERE is the diagram - maybe your monitor has better resolution... but it looks fuzzy to me.
    Let me know If i can help further.
    Thanks!!
    Brigadier General:
  • 3,614 Answers
Do completely defrosting first the unit. Better to move any food that need to be refrigerated on other fridge available, this will help you determine if the evaporator fan was faulty. also defrosting the unit can resolve this issue.
Let me know for any clarifications
  • micromaster
    micromaster Jun 15, 2009
    did you already check the door rubber gasket if it is properly fitted on the unit.?
  • micromaster
    Sometimes it happen that the refrigerator gasket (usually a rubber seal
    around the door) becomes hard or cracked, its seal is broken, and the
    unit's efficiency drops sharply.
    You can test it by placing a
    dollar bill between the gasket and the door jamb by closing the door.
    Pull out the $ bill, if it gives some resistance, means the gasket
    works properly. If the bills comes right out, or fall out, this means
    that you have a faulty door gasket and you should replace.
    Test the door on several locations around the door to check the door for leakage.
    Hope this initial info helps.
Freezer cools well, refirgator is warm, the vent that brings air from frezer to refrigator has no air movement, ice inside , i broke some ice with knife shoul di spray hot water to get rid rest , I did...
This answer will be somewhat long, but in order to understand the "fix" for your problem you need to understand how a refrigerator-freezer works.
Most units have ONE COMPRESSOR which usually cools the FREEZER. Then, to cool the fridge area, there is a DUCT or ducts between the freezer and the fridge area to move some small amount of very cold freezer air into the fridge section. In the old days this occurred by convection, but most newer units have a small fan in the duct to more dependably move the air.
The run time of the compressor, and thus the temperature of the freezer is usually controlled by a THERMOSTAT [usually with numbers on the dial]. A second control [usually with the letters A, B, C, and sometimes even D] operates either a DAMPER in the duct, or controls the duration of fan operation in order to control the temperature in the fridge section.
Under certain conditions of higher humidity, FROST [fine ice crystals] can build up in the duct, and on the fan if there is one, reducing or totally blocking the cold air flow from the freezer to the fridge section.
From your description of the freezer working well, but the fridge section being "warm" suggests that blockage of the duct is what has happened. However, there are a couple of other possibilities:
1. You inadvertantly moved the fridge control to a warmer setting,
2. You inadvertantly placed something in the freezer and/or fridge which BLOCKED the entrance or exit of the duct,
IF one of the above are the cause, a "manual" defrost of a few hours with the freezer and fridge doors open to allow warmer air in should melt out any frost/ice from the duct and allow the system to work properly. Depending on the severity of the frost/ice buildup, it could take a couple of days to fully melt all the frost/ice.
During the manual defrost ALL frozen and perishable foods should be temporary stored in an ice chest or cooler of some kind.
One more thing, in addition to heavy humidity, frost/ice buildup can also be caused by a defective automatic DEFROST TIMER. IF the system does not do its regular defrost cycle [usually an hour or two once in each 24 hours], then frost/ice buildup can occur even with "normal" humidities.
So, once you have the system back in operation, watch for the normal cycling of the defrost program, and if the problem continues, contact a qualified refrigeration repair technician to repair or replace the defrost TIMER.
Jul 13, 2011 | Refrigerators
I have a magic chef refrigerator that is not cooling. The freezer is working but nothing is staying cold in the frig. Could this be the thermostat?? Don't want to replace frig for a number of reasons. ...
next time send the model number,where is the freezer is it on top or bottom or side by side,anyway all the fridge does is get cold in the freezer and the evaporator fan blows cold air from the freezer into the fridge section and then it returns to the freezer just goes around until it gets cold enough and then the t-stat tells it to shut down so if the freezer is cold you either have a bad fan motor,open the freezer you should hear the fan blowng around in there if not the evap fan motor is bad,also touch the back inside wall of the freezer if there's any frost or ice on the back inside wall you have a defrost problem,bad timer or board,bad defrost thermostat or a bad defrost heater,the ice doesn't melt off of evap coil because one of the parts have failed,the air ducts get blocked with ice and the cold air can't blow into the fridge section,or if you see ice on the ceiling,side and back walls the door was left open and the air ducts blocked with ice,or one more thing if the freezer is on top and you have water dripping into the fridge section the drain in the freezer is blocked and the defrost water can't go down the drain hose,the water is freezing the air ducts up,the drain has to be cleared and all the ice has to be melted out,and yes there is one more thing it could be, some fridges have a damper in them,all it is is a door that opens and closes to let the cold air from the freezer blow into the fridge section so this is why you have to send the model number.but your problem is the cold air in the freezer isn't getting blown into the fridge section because the fan isn't working or the air ducts are blocked with ice.
Dec 31, 2017 | Refrigerators
Have the bootom freezer. what is happening is the freezer works and the top part quits cooling and the fan quits working. we took everythinhg out and transfered to the outside frig. we unplugged the...
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door.
However if fan has quit totally then it will have to be replaced since it is responsible for cooling the upper part of the fridge
Dec 28, 2010 | Amana ABB1927DE Bottom Freezer...
The freezer works great, but the refrigerator isn't cooling properly as of yesterday
Check the vents coming into the frig from the freezer and with the fan in the freezer blowing feel if there is any air blowing into the frig., if not then check for ice buildup in the freezer. sometimes the ice will block the fan and or vents. Defrost if there is frost and ice buildup.
Mar 09, 2010 | Whirlpool Refrigerators
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Refrigerator will not cool It stays at 50 degrees Freezer works fine
Look for a blocked duct or a bad fan motor in the freezer. The cooling is done in the freezer and the cold air is circulated via ducts and a fan. No air flow= No cooling in frig. Long shot could be a light not going off when door is closed, seen that a few times in 20 years...
Eric
Nov 08, 2009 | Refrigerators
Line and air flow box between freezer and frig freezing up, we took apart, defrosted . air comes into frig, but still not cool enough. freezer works great This is a side by side model # ED25PWXAN01
If the fan is running in the freezer compartment, temperatiure is normal, and no frost is building up on the back panel in the freezer panel, then there is a good chance the return air shutes in the fresh food compartment are blocked with ice. The return ducting is just as important as the the supply shute which you melted out. Difficult if not impossible to see.
My recomendation is to empty, unplug and air dry the whole machine preferably with a fan blowing air into the fresh food compartment.
Haste makes waste with this machine. Using heat can cause the plastic shutes to melt and distort.
Should be defrosted in this manner for 24 hours.
Restart and give the machine 24 hours to recover. Common problem with Whirlpool products.
P.S. Check to see if lights go out when closing fridge door. In fact this should be your first step. Jack
Nov 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Problems with my GE frig side by side freezer working but not frig
check fan in freezer for blockage,damage or not working if fan hums and no air, blocked or seized -repair /replace if blowing air look for ice or blockage in fan duct and that damper is open
Oct 15, 2009 | Frigidaire Refrigerators
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
96 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
